1 PPS clock source issues: Basic Stamp frequency counter?
Hi all-
So I finally finished the Nixie clock I've been working on for a LONG time. However, the 1PPS source I built doesn't quite seem to run true: It gained about one second over 6 hours. Now my nicer multimeter is at my appartment at school and the scope I have at home has a broken trimmer on the time/div knob so I don't know what exactly it's set to.
The examples I worked off of say that I can get 32.768 kHz at one test point in the circuit, but I don't have anything to measure this with. Is a Stamp 2p fast enough to be programmed as a frequency meter, and if so how would I go about doing that?
Raf
UC Berkeley '12 EECS
CalSol: Berkeley Solar Car team
www.calsol.berkeley.edu
KJ6AWU
Post Edited (FlyingFishFinger) : 1/6/2010 8:41:13 AM GMT
Raf
KJ6AWU
The easiest way to get an accurite time base is to count the zero crossing of the AC line. Divide bt 120 and you have a 1PPS signal.
The Line Frequency is 60 Hz +/- .1 hz. This in its self is not too accurate but the power company monitors and corrects the frequency.
If it runs at 59.9 hz for 127 cycles then they will speed it up to 60.1 hz for 127 cycles.
Over a long time, like hours or days the timing is very accurate, and this is why most AC powered clocks keep such good time.
Anyway just my 2 cents worth.
Hope it helps
Alan Bradford ·N1YMQ
Plasma Technologies
Canaan NH 03741
www.plasmatechnologies.com
I am not sure if the Stamp is fast enough, maybe the SX or 2P might be.
The problem is the Stamp time base is not that accurite and you would still need a scope or other type of acurate piece of test equipment to calibrate it.
Good luck,
Plasma Technologies
Canaan NH 03741
The frequency source is supposed to be adjustable with a variable capacitor, but I don't have anything to measure the test point frequency with. Actually, I also have a Prop around. Would that be good enough?
Raf
KJ6AWU
I have not been able to 'Cog' my brain in to the Prop programming.
My head "Spins' when·I think about it.· (I·have been a·Basic junkie since 1969 and can only think of one thing at a time!)
If·the Prop·has a crystal time base, but it may not be much more accurate than your 32 khz on the clock.
If time is not an issue (pun intended), you could tweak your clock timebase a little bit, wait 6 hrs to see if it drifted, and if not your done, if it did then repeat.
You could use WWV as your time base.
Eventually you will get get it right on.
Good Luck,
Plasma Technologies
Canaan NH 03741
At my work we have an atomic clock, and unless you run the counter from the atomic clock you are really just comparing the clock to the clock inside the counter (which could be worse than the clock you are trying to measure).
I would suggest using the·1pps from a GPS receiver.
Bean.
Use BASIC on the Propeller with the speed of assembly language.
PropBASIC thread http://forums.parallax.com/showthread.php?p=867134·
KJ6AWU
