Fund Raiser
Moderators please forgive this post I admit it is a far stretch but it is related.
I have a few big projects I want to get up and running but I need to get some money to do so. So I have put some of my old stuff up on EBay. If you are interested please bid early and often.
In order of most related to electronics to least:
50+ 74HC154 - 4 to 16 Decoder - We always need more pins
Waterproof GPS Data Logger(BGT-11) - Track your robots moves or hack it up and get yourself a screen, GPS Unit, rechargable batery and some cool butons
Ikelite DS51 Substrobe/TTL Sync Cord / Strobe Arm - your under water robot needs some light so why not use a high powered professional diving flash. it will servive depths greater then your robot probably can. Probably better to use for taking pictures of the robot though.
DVD Burner and 2x USB Card Readers - Record your robot home videos or hack them up for parts. you decide.
68/4500 Carbon Fiber Rapped Tank and Rhino Cover - batteries are great for powering motors and running logic but what if your bot needs some more power. This tank can deliver 800PSI of pressure enough to power the most demanding of pneumatic devices.
Camoflash Paintball Mask - you armed your bot with all kinds of cool weapons and sensors and now it has come alive. Protect yourself and blend in(hope you have a tree in your work shop) with this mask.
Panoramic Head - In preparation for launch of your new robot you may want to take some high res panoramic pictures of your surroundings first.
4 Pod Harnesses - I have no clue what your robot will do with these(on second thought I am pretty sure they would make good pontoons.
24 bit LCD Breakout Board now in. $21.99 has backlight driver and touch sensitive decoder.
