Independent Power Supplies
I am using the Parallax Professional Development Board with a BS2.
My application requires ultrasonic sensors that require a supply voltage of 15-30VDC with maximum current consumption of 35ma that produce an output signal of 0-10V / 10-0V.
I am very new to this field and would like to have a completely independent non-battery power supply for the ultrasonic sensors to separate them from the Development Board circuitry (which uses a Parallax 12V 1A wall power adapter). Would I want to obtain perhaps a 15V wall pluggable switching power adapter and if so should I incorporate some type of circuitry to ensure the proper output voltage and current? What current rating should the plug-gable power supply have? Is there a better method than this?
Also, how would I interface the 10V output signals into a ADC chip that resides on the BS2 development board?
In advance, many thanks!
A simple voltage divider could take a 0-10V signal and reduce it to a 0-5V range for use with an ADC chip.
