Flywheel and rotozip physics help needed
I am well on my way to finishing a 12 x 12 CNC machine that I plan to use a rotozip on.
My question to the physics people here is would a flywheel be a benifit for slower speed cutting.
Typically I cut 6061 aluminum at 500 to 1000 rpm on my Bridgport and it cuts like butter wit zero chatter.
My thought on the rotozip is that reducing its speed with a speed controller will also cut its power.
Using a 2 inch x 1/2 inch flywheel would allow more current (more power) to drive the motor at a slower speed and also help absorb vibration of the cut.
I have a guy that can make me a flywheel but do you think this might work, any merit to the idea or am I just thinking too hard.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
Generally speaking, a flywheel is used to store mechanical energy in a system but the flywheel can "output" that energy for only a short while. A flywheel is analogous to a capacitor in that respect. The flywheel is used to smooth out mechanical motion, so it might help with phenomena like chatter during a cut. But as Phil points out, the flywheel is not going to give you power "in the long run" if your system can't pump it in somewhere in the cycle. For example, you would not expect a capacitor to pull energy out of thin air: at some point the capacitor needs to get "recharged" during operation.
hope that helps,
Mark
Flywheels are typically used to maintain constant speed, or to store up energy for impact.
They don't do much for power.
Signature space for rent!
Send $1 to CannibalRobotics.com.
If the head is stationary, there shouldn't be many problems. The bit moving will do the same thing but in much less magnitude.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
Phil,
Yes you are right. I was mistaken. The tilt of an axis will cause a offset movement 90 degrees from tilt.
James L
James L
Partner/Designer
