Brick Sorter
I am looking into building a robot that can sort black and red lego blocks. I see that there are a lot of stuff on the web for the lego mindstorm but am specifically looking to make one using the basic stamp and my boe bot kit. Just looking for some guidance as to what is the best sensor to use to be able to tell apart black from red and that works well with the stamp. I appreciate any advice. Thanks.
Red will show up as red and the others should be some where in between.
If you are going to use other colors, some of the darker ones will get confused with the black because of the filter.· Lighter ones might not be detected at all.
Bill
Vla7
