Propeller IDE files
Is there a way to tell the IDE where to get and store files? Storing your working and spin files in the Program Files directory is not a good idea and is getting harder to do as MS tightens security policies.
- Stephen
- Stephen
In the propeller tool V1.2.6 there is no way I can find to set a "default" folder. However, the prop tool opens with the last folder you used before closing it. To save files to a different location use "Files > Save As..." You can also use "Files > Save To..." where you will be presented with a few common destinations such as the Propeller Library folder and a history list of recently used locations.
Regards, David
