Data logging madness
hi all,
I've ben tinckering around with the propeller and the Parallax data logger for a few days now and just got all the connections together. However I've having difficutlies connecting to the logger and writting to it. When ever I try to use the object USBdata (http://obex.parallax.com/objects/204/) I can never connect. I have no idea whats wrong, i've tried different objects, different pins, different flash drives, with series resistors and without, I'm completly lost.
I tried a different program somone else created (http://www.hapb.net/documents/documents.html) and it seemed to be able to connect however not write. (red light stayed on, but did not blink and no data in the flash drive)
I might be doing some newbie mistake, so.... Help is·greatly appreciated.
Powered by enthusiasm
What hardware board are you running the Propeller on?
Can you talk successfully to the Propeller _alone_ from your PC?
Can you talk successfully to the flashdrive _alone_ when plugged into your PC?
Regards, T o n y
Currently I have a propeller 40-dip chip connected on to a breadboard with a 3.3v regulator and a 5 mhz crystal.
I can talk succesfully if you mean downloading programs and the prop tool recognizing the device.
And yes I can communicate to the flash drive from my computer.
@SRLM
I used you hardware connections (pin 6 to ground) and now it seems like the flash drive detects the monitor even when I didn't write a program. Is this normal?
Can you post a quick photo of the breadboard so that we can give it the once-over?
T o n y
