I dont have a decoder and encoder...how to make encoder and decoder using propeller? I just have RF module TX and RX (see attachment) ...anybody already make this project ? can anybody help me....
Once your project is working in this basic configuration, then consider the transfer to the Propeller. Here again, I would take the easiest route and use PropBASIC from here:
www.propbasic.com/propbasic.zip
Leon
Amateur radio callsign: G1HSM
I want to send data·using RF..
We're all trying to tease a little more information from you, to point you in the right direction.
In the meantime, the following advice will get you from where you are now, to where you want to go -
Start with the easiest and fastest solution:
Buy the similar units from Parallax, together with one of the their Basic Stamp kits; then use the code that they supply to get your project up and going. Here's the code:
http://www.parallax.com/Portals/0/Downloads/docs/prod/rf/27981-ParallaxRFReceive-v1.1.pdf
Alternatively, Sparkfun have PICBasic code for your Laipac units here, which could be adapted reasonably easily :
http://www.sparkfun.com/datasheets/RF/KLP_Walkthrough.pdf
Good luck!
To n y
Post Edited (TonyWaite) : 1/3/2010 1:07:40 PM GMT
