clkfreq timing ?
Hello all
·I'm following the SIRCS,Propeller style article in the Jan.2010 issue of Nuts&Volts by Jon Williams. The sircs start bit "as stated" is 2.4ms and the statement "· START_BIT := clkfreq / 1_000_000 * 1_920· " is used.
My·question is how does this equal 2.4ms ?
I've looked at the· clkfreq·explanation on pg.175 of the Prop.Manuel, But I seem to be missing something.
Thanks in advance for any info/help on this topic.
The Truth is out there············___$WMc%___···························· BoogerWoods, FL. USA
Post Edited ($WMc%) : 1/1/2010 6:58:43 PM GMT
In the code archives for the article (downloadable from Parallax's Nuts and Volts webpage), the constants look like "CLKFREQ / 1_000_000 * 2400". Where did you get the 1_920 value?
· 2400 sounds more like it.
Heres the code I downloaded from the Prop.Obj.Exc.
Now I really understand the 1920 value. I hadn't thought of a short start bit. I see he did the same thing with "ONE_BIT".
I'll add this 80% of value to the REM code so I'll remember later.
Thanks again
