PING)) penguin
Capt.Kerry
Any code out there that utilizes the PING )) sensor to help navigate the penguin?
One of my favorite programs is the Penguin Seeing Eye Dog. There are versions that incorporate the PING))) and the segment display and provide an audible tone that varies based on the distance to the object. There is another version for dark night navigation that detects obstacles in the front, out to a distance around 10-feet, and you can check the code in the Penguin Superhero section for more.
www.p-robot.com/index.php/vision.html
www.p-robot.com/sources/Vision.zip
www.p-robot.com/index.php/penguin-superhero.html
www.p-robot.com/sources/superhero.zip
The Penguin PRS web site is updated here.
www.p-robot.com/
humanoido
*Stamp SEED Supercomputer *Basic Stamp Supercomputer *TriCore Stamp Supercomputer
*Minuscule Stamp Supercomputer *Three Dimensional Computer *Penguin with 12 Brains
*Penguin Tech *StampOne News! *Penguin Robot Society
*Handbook of BASIC Stamp Supercomputing
*Ultimate List Propeller Languages
Post Edited (humanoido) : 1/3/2010 6:50:57 AM GMT
I have found code for the boe-bot that uses the PING)) to detect and move toward an object and I was anxious to see if something similar could be applied to the penguin?
I just got a Penguin for Christmas and am new to programming so I wanted to make sure that there wasn't some reason why this couldn't be done. Especially as you have been so busy writing all these excellent "apps" for the little fella and have'nt seemed to have gone down this path yet.
I note from the Boe-bot "go_to_closest_object" code that the PING)) sensor is mounted on a servo to scan back and forth. Obviously not possible with the penguin. Would·a static·sensor have a wide enough operating angle to·enable the robot to determine the direction of an object or is it really only effective as a distance measurement device?
Thanks for your input.
