SX-Key no longer working... replaec with SX-Blitz? — Parallax Forums
ClintClint Posts: 95
edited 2010-01-04 17:49 in General Discussion
My SX-key seems to have stopped working mysteriously (I get a "SX-key not found on com#"). I have been using it for several weeks programming SXs with the same program every time and it has worked fine up until today. I have tried things like restarting my computer, reinstalling the Parallax USB-to-serial drivers, installed the latest version of the SX-Key editor, tried programming different SXs with different boards and power supplies... no luck. I'm thinking my SX-key is probably just bad for one reason or another and it's time for a replacement.
Since I am just using the same program over and over, will the SX-blitz work for me? Reading on the Parallax website it seems like it will work fine for programming SXs, it just lacks some debugging capabilities which I don't use anyway.
I'm also curious what sorts of things might have caused my SX-Key to stop working. The board I am connecting it to during programming is powered by batteries through a 5v LDO regulator. There is a 50mHz oscillator connected to the SX on the board and I'm wondering if it's okay to have that connected while programming (I read somewhere that it was okay). What about a loose connection between the header and the SX-key? I've noticed sometimes I would get a chip connection error and I could get it to program after "jiggling" the SX-key on the header.
Thanks for any help,
Clint
    edited 2010-01-01 00:28
    I had trouble with an SX_Blitz or so I thought.· It was my supply, just a bit marginal.
    Sounds like your connectivity is suspect.
    You cannot program with an oscillator in circuit, that's a no-no, that'll wreck your tool.· (A crystal is OK and a resonator is OK.)
  • ClintClint Posts: 95
    edited 2010-01-01 04:35
    Sorry, I wrote that incorrectly. I am using the 50mHz industrial resonator from Parallax (PN 250-05060). Is that okay to have in the circuit while programming?
    I have a 4pin header soldered to my PCB. It's a straight version of the 90 degree header that comes on the SX tech board. It should make an equivalent connection as the one on the SX Tech board.
  • Martin HodgeMartin Hodge Posts: 1,246
    edited 2010-01-01 05:33
    Resonators and crystals are okay to leave in during programming. TTL oscillators are not as they can not tolerate the 12.5v programming voltage. I had an old serial SX-Key go bad recently. I noticed occasionally it would just lock up and draw several hundred mA. Had I set the current limiting on my power supply correctly I might not have burned the key up.
    edited 2010-01-01 08:52
    I have Vdd to Vss at 5v during programming. Is that incorrect? Where does the 12.5v come in?
    edited 2010-01-01 17:16
    The 12.5v is generated on the key/blitz and applied to OSC1 during programming. When you have a TTL oscillator connected to OSC1 at the same time it will not like the 12.5v and blow, likely taking the key/blitz with it. But since you're using crystals or resonators only, don't worry about it. It sound like a blitz is fine for your needs as long as you don't need in-circuit debugging or the variable clocking function of the key.
    Martin Hodge
    (Long Live the SX!.... aw Smile)
    edited 2010-01-01 20:16
    Clint, contact our tech support on Monday and we can get you a replacement.
    Viva la SX!
  • WhitWhit Posts: 4,191
    edited 2010-01-01 23:34
    Congrats Clint! Parallax comes through again.
    Love the new look Ken - I saw it when you first posted it - sorry for the delayed comment.
    Whit+
    edited 2010-01-03 01:09
    Ken Gracey (Parallax) said...
    Viva la SX!
    That is awesome. Thank you!
    edited 2010-01-03 23:53
    Shmoopy said...
    Martin Hodge
    Thanks for the added info. Does the 12.5v get applied anywhere other than the OSC1 pin?
    I have I/O connected during programming so I just want to make sure I'm not hurting anything.
    edited 2010-01-04 02:03
    Nope, just OSC1.
    THANK YOU PARALLAX!
    This morning I talked to Josh in tech support and Chantal in sales. They were both very friendly and helpful. Unlike a lot of so-called tech support I've received with other companies, there was no anxiety or headache - just a friendly conversation between people trying to figure out a problem.
    Parallax is sending a replacement SX-Key free of charge and I bought an SX-Blitz for backup. I just want to say thank you for the great support!
    Post Edited (Clint) : 1/4/2010 11:36:51 PM GMT
