Surface Mount crystal
Hello Guys,
Can anyone recommend a crystal for the prop that is surface mount?· Thru-hole just isn't as much fun especially if I want to swap things out.
Thanks,Greg
Thanks,Greg
Style and grace : Nil point
It's good to 85C. I use it for both surface mount and through-hole (just bend the tabs), might not be good in breadboard though.
April, 2008: when I discovered the answers to all my micro-computational-botherations!
Some of my objects:
MCP3X0X ADC Driver - Programmable Schmitt inputs, frequency reading, and more!
Simple Propeller-based Database - Making life easier and more readable for all your EEPROM storage needs.
String Manipulation Library - Don't allow strings to be the bane of the Propeller, bend them to your will!
Fast Inter-Propeller Comm - Fast communication between two propellers (1.37MB/s @100MHz)!
24 bit LCD Breakout Board now in. $21.99 has backlight driver and touch sensitive decoder.
