MAX 6675 Thermocouple to serial interface chip.
HI, I am again having the same problem with this chip as I was with my old circuit that I built. The purpose of this circuit is to convert thermocouple signals to something that my basic stam can understand. I have the circuit built right onto the thermocouple head to eliminate any possible outside inerference, but something is going on.·It is in a loop. and this is suppose to be reading the temparature as I am heating up the thermocouple. I am Suspecting the power supply or feedback from the stamp, but is still am not sure. Tonight I will be putting the scope on it so see, but I am not sure if I am going to find anything. Any Idea's? My screen in run mode looks something like this.
600
600
612
540
500
0.0
0
14.25
590
600
·Thanks, MorteAzure.
600
600
612
540
500
0.0
0
14.25
590
600
I have used this chip a lot. It is very reliable. I have tons of them.
The chip is very specific on the Thermocouple connection. Also, the thermocouple will read the ambient temp.
The readings are usually very accurate in Celsius. They are designed for K type thermocouples, and will have some error with different types.
I'm sure this doesn't help much, but should get you started.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
www.emesystems.com/OL2therm.htm#MAX667x_description
It is a good idea to include a bypass capacitor on the power supply right at the chip. If there is ripple on the MAX6675 power supply, you should be able to see that on the oscilloscope.
It looks like there may be something wrong with the PBASIC code.
Tracy Allen
www.emesystems.com
Post Edited (MorteAzure) : 12/31/2009 11:18:32 PM GMT
