PNA4602 error in the book???
HI guys I am doing the IR project for the prop BoeBot I downloaded the code it comes with a schematic to show you how to configure the circuit "PID Following Propeller Bot""" but in that drawing it shows the 4602 connecting the way in the drawing I attached but in the book "prop education kit and Lab fundamentals" It show the 4602 with the ground pin in the middle 5 volts on the top pin and the prop signal going into the bottom pin its the same orientation so which one is the right way to wire the device .? I did try looking up data sheet but it does not show pin out go figure. Thanks guys.
The signal is not normally in the middle so I would think the attached diagram is not correct.
Graham
