USB BoE and Hyperterminal
Hi All,
I've used a serial BoE and BS2pe for some time now running a weather station. Data is collected once a week simply by using Hyperterminal and DEBUGging the stored data to a text file on the PC. I use a null-modem (is that the right term?) cable so the BS2 doesn't reset when HT connects.
I've now got a second BS2pe and a USB BoE so I can do some development work. The connection appears as COM7 on my system and all is working fine except that when HT makes the connection the Stamp resets. I really don't want this to happen, but can't see any settings to change within HT. Does anyone know of a workaround for this, or possibly a more elegant way of collecting the stored data? We're not talking huge quantities here, about 70 kb per week.
Thanks, and a Happy New Year to all when it arrives.
Ken.
Ken.
- Stephen
Cheers,
Tom Sisk
http://www.siskconsult.com
The physical workaround is exactly what I've done with the serial BoE, but I'm not sure if that's possible with a USB BoE, which is what I'm having the problem with.
Ken.
Cheers,
Tom Sisk
