basic stamp/memsic sensor
i have used this code before with four shift registers, a memsic sensor and basic stamp. i am only using three shift registers now. that means I am using 8 pins but cannot change the code to get all of this working. Can anyone help? Please, I am desperate.
' {$STAMP BS2}
' {$PBASIC 2.5}
Clock PIN 0
SerData PIN 1
Latch PIN 2
Clock2 PIN 3
SerData2 PIN 4
Latch2 PIN 5
Clock3 PIN 6
SerData3 PIN 7
Latch3 PIN 8
Clock4 PIN 9
SerData4 PIN 10
Latch4 PIN 11
Delaytime CON 100
pattern VAR BYTE
x VAR WORD
y VAR WORD
Reset:
LOW Latch
pattern = %00000001
Main:
DO
GOSUB Out_595
PAUSE DelayTime
pattern = pattern << 1
LOOP UNTIL (pattern = %10000000)
DO
GOSUB Out_595
PAUSE Delaytime
pattern = pattern >> 1
LOOP UNTIL (pattern = %00000001)
GOTO main
Out_595:
SHIFTOUT SerData, Clock, MSBFIRST, [noparse][[/noparse]pattern]
SHIFTOUT SerData2, Clock2, MSBFIRST, [noparse][[/noparse]pattern]
SHIFTOUT SerData3, Clock3, MSBFIRST, [noparse][[/noparse]pattern]
SHIFTOUT SerData4, Clock4, MSBFIRST, [noparse][[/noparse]pattern]
PULSIN 14, 1, x
PULSIN 15, 1, y
IF x < 2300 THEN PULSOUT Latch, 5
IF x > 2800 THEN PULSOUT Latch2, 5
IF y < 2300 THEN PULSOUT Latch3, 5
IF Y > 2800 THEN PULSOUT Latch4, 5
RETURN
END
' {$STAMP BS2}
' {$PBASIC 2.5}
Clock PIN 0
SerData PIN 1
Latch PIN 2
Clock2 PIN 3
SerData2 PIN 4
Latch2 PIN 5
Clock3 PIN 6
SerData3 PIN 7
Latch3 PIN 8
Clock4 PIN 9
SerData4 PIN 10
Latch4 PIN 11
Delaytime CON 100
pattern VAR BYTE
x VAR WORD
y VAR WORD
Reset:
LOW Latch
pattern = %00000001
Main:
DO
GOSUB Out_595
PAUSE DelayTime
DO
GOSUB Out_595
PAUSE Delaytime
GOTO main
Out_595:
PULSIN 14, 1, x
PULSIN 15, 1, y
RETURN
END
2) You haven't explained very well what you want. What you posted is obviously something for 4 shift registers. Explain what you're trying to change and what does or doesn't work in the 3 shift register version.
3) You might post what you've got for a 3 shift register version
