No BASIC stamp found
···· HI!· Help.· I am a new Boe-Bot user.· I am following the manual provided with my new Boe-Bot.· My computer acknowledges the fact that there is a cable running into the computer (USB).· However, the computer will not recognize any BASIC Stamps, even though I have a BS2 in the correct spot.· I am using a computer with Vista.· The manual does not include any information regarding Vista.· I found the section that explains to change in the Device Manager·=> Ports =>·Port Settings => Advanced. It says to uncheck the box labled "Use FIFO Buffers".· I do not see anything about FIFO buffers.· Any help would be appreciated.
http://forums.parallax.com/showthread.php?p=867712
When I press Run => Identify to test to see if the STAMP Editor registers the stamp, the "Device Type" and the "Version" columns are blank, even though Yes shows in the "Loopback" and "Echo" columns.· The computer identifies the port (if the cable isn't plugged in, Device Manager doesn't show COM4, my port), but not the actual BS2.
Boe-Bot ROCKS, dude!
So does math and Guitar Hero!
d/dx (3x^2 + 5x - 3) = 6x + 5
TTFAF!· SO HARD!·Max. score: around 320K
- Stephen
