Case prototyping
I need a custom plastic case for my project.· Plus, it would be nice to have a prototype case.· This project is funded by the company known as My Wallet, so I can't go pay an industrial design firm.· Does anyone have any recommendation or experience with a particular CAD tool and/or prototyping house?
Leon
Amateur radio callsign: G1HSM
Rule No. 1: What Leon said.
It is generally much easier to fit a project to a case than find a case to fit a project.
Rule No. 2: Use plastic unless metal is absolutely necessary. Plastic is much easier to work.
Rule No. 3: Choose a design where the end panels are separate pieces of flat material.
Unless all you need to do is drill a couple of holes, those cheap metal cases made from two U-shaped pieces of bent metal are very awkward to work with.
For front and rear panels, it's much easier if you have a simple flat piece you can work on (and if you mess up, its much easier to replace also).
- Rick
openscad.org/
My drilled holes usually turn into jagged messes or I end up with a cracked case. And yes I start with a small bit, working up to the final size.
DJ
i have found that drilling at a high speed usually gives me better results, just my 2 cents worth though....
Leon
Mr. Pilgrim - well actually, I have a Unibit but never thought it would be appropriate for plastic. I'll give it a go.
Leon - by 'taper drill' do you mean a Unibit?
Thanks all,
DJ
Fabricating with styrene is a breeze. Comes in every sheet thickness and rod diameter you could want. Score a line with an exacto knife & snap it for a perfect edge. Solvent bonds extremely well with MEK or equivalent. Paints well, and pretty tough too.
CA glues (superglues) work very well. Use medium or thick glues with an accelerator (kicker) for good bonding. Another trick is to use thin superglue with baking soda, it forms a rock-hard, strong, machineable blob. Useful for fillets, repairs, or even making small parts from scratch by building up, layer by layer.
You could also start with a Radio-Shack type styre project box for general size & structure, then glue on styrene externally for the final shape.
@Erco - baking soda and super glue?!?
DJ
is the ancient art of mold making. Design it in clay. Make mold out of plaster of paris. Then
use plastic resin for the case. A while back I found a site selling a non-toxic plastic resin (most release pretty nasty fumes)
but lost the link.
A video link
Post Edited (Thomas Fletcher) : 12/28/2009 10:13:27 PM GMT
For fabbing the case, you could consider something like laser cutting or 3D routing with machines like ShopBot or similar. If you have a nice design and are easy to work with, you might be able to use the forums to find a hobbyist with a 3D routing machince and would machine the case at a minimum cost. In fact, ShopBot has a program where they are setting up 'garages' around the country so that those who own ShopBots can offer easy to use services for machining.
What is the case going to look like? What do you want it to be? Do you have any hand sketches?
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
No, that's a step drill. It's this sort of thing:
www.machinemart.co.uk/shop/product/details/cht382-3pc-tapered-drill-set
Leon
Helpful to keep fresh BS in a squeeze bottle with a narrow tip to dispense. Keep CA & BS tips out of the soup or you'll spend half your time unclogging the tip. You heard it here first!
http://www.core77.com/design.edu/tools/model.html
http://www.scalecorvettes.com/hints%20&%20tips/hints09.htm
http://www.robotbuilders.net/r2/
http://bobgreiner.tripod.com/
@Erco - and thank you for the info. From revealing finger prints to hanging hard-hatted people from I-beams to maybe even repairing a cracked engine block...what can super glue NOT do?!?
(...smiles...)
DJ
construction with easy access to all faces. Either in aluminium or plastic.
Then find your nearest one or two-man sheetmetal workshop: they will have all the punches, drills,
experience and _skill_ required.
For far less than the cost of the tools you can have a professional job in a fraction of the time.
Listen carefully to their advice. And when you're there, try a skills swap. Chances are that they've
got computer/electrical/electronic issues that need sorting and money need not change hands.
This advice may seem counterintuitive. I've got a small milling machine and tooling, a precison pressbrake
etc, but only use them on the weekends when my favorite toolmaker and sheetmetalworker are
unavailable.
T o n y
