Why wouldn't my prop demo board be recognized?
I bought one of these and the prop IDE and 12blocks is not recognizing it, any idea why?
I can see it cycles it's mini LED's when I plug in the USB portion? It has a green light illuminated and is getting 9v?
Any ideas?
Any ideas?
8x8 color 80 Column NTSC Text Object
Safety Tip: Life is as good as YOU think it is!
I'm using the cable that connects to my prop breadboard, and it is working with that?s
What version PropTool IDE are you using?
The demo board has a FDTI chip that may be wanting to use another Com port. You may have to reset it in Preferences in the PropTool.
1) No power to the board or inadequate power
2) No communications. Could be the USB cable. Could be the USB I/O driver. Try a new cable. Try reinstalling the Propeller Tool. hover1 may be right if you still have your other board connected to your PC. The Propeller Tool (and 12Blocks) can switch among several connected Propellers. Check which COM port it's using.
Lastly and very rarely ...
3) The board could be broken. This is very unusual, but can happen. First try to fix #1 and #2.
I have version 1.2.6 of the propeller IDE
I had an issue like this a year ago, and I fixed it by uninstalling the old prop tool AND USB drivers, and then reloading the PropTool AND the USB drivers that came with it. Would suggest upgrading to PropTool 1.2.7.
Jim
My power cable that I borrowed from the answering machine, was not playing nice with the demo board for some reason? It said 9vdc?
Anyway, in case anyone finds this in a search, the prop demo board wants a positive tip. If I get a chance, I put the tip size in my micrometer and post that as well
Potatohead said to try a different cable, but I did the inverse of that and tried my prop breadboard instead of the demo board on the same usb cable.
You can use the Radio Shack "M" plug with some of their multi-voltage supplies.
http://www.radioshack.com/product/index.jsp?productId=3807939
I just bought seven 6volt 1800ma supplies for $2.97 each! Part number 273-1763. And a free Adaptaplug to boot! You can't buy the on-line anymore, just what's left in store stock. Think I got all that was left in Tennessee and Alabama.
Jim
If you're anywhere near the northern Baltimore area, there are these guys:
www.baynesvilleelectronics.com/index2.ivnu
Unlike your standard Radio Schlock, they have people there that can sometimes answer real questions with experience and aplomb.
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
Post Edited (kf4ixm) : 12/27/2009 6:33:01 PM GMT
The 600mA is $14 and the 1300mA is $18
Do you have thrifty, second hand, good will type stores near by? If so, they have tons of these things with every imaginable connector type, output voltage, AC, DC, you name it.
$5 will probably get you a couple, and worst case is having to cut 'n splice the right connector onto the right power supply.
Jim
