How do I do a Software Reset?
Could it be LOW 22 ? 22 is the pin number and the manual says to drive it low to reset. The reset button itself seems to be a simple connect to ground - which would drive it low i guess.
The manual also states to never drive it High, it is internally pulled high. or is this topic a
have not yet gotten the 'mindset' of inputs being outputs and vice versa.
: might be a solution to not really this topics thread as it was started:
As i am out of pins and when the program is running it would not be able to 'read' a button press anyway... I added a wire from Vss to a button and from that a wire soldered to where the physical reset button is... i need to 'hide away' the board-wires etc and yet be able to hit the 'kill switch' when something goes haywire. The button is in-on a container that WILL be accessable (sp?) . Not Elegant- probably not wise- but o well .
