DC Motor Question
JohnBot115
I'm very new to robotics, so sorry for the stupid question. But I don't quite understand how to calculate how many amps a motor will draw, with load.
Lets say I have a 3 to 12 volt DC motor capable of about 520 oz-in. The specs say that at 12 volts it draws no load of 45mA.
Great, at first I thought that I could just get a 12 volt battery capable of producing 1 amp, and I'd be good. But if I intend to put a load of about 500 ounces on it, from my understanding, it will draw more amps. That's ok, but how do I know whether to get a battery capable of handling 3 amps or 7.
So, how does one calculate amps needs? Thanks!
In case you're wondering, here's the motor I'm thinking about purchasing.
http://www.servocity.com/html/4_rpm_gear_motor.html
Just a quick clarification: If I were to buy a DC wall transformer rated at 12 volts and 3 amps... is there any possibility of burning the motor out? I'd like to buy a transformer that I can hook up to my breadboard for prototyping. That said, I'd like to get a one with some power. Just to have available for projects generally. So 12v / 3 amps seems good. But if that can burn out a motor only rated at 12 volts with a max efficiency rating of less than one amp, maybe I should not?
One possible disadvantage in buying a power supply rated at much more than you expect to use is that they're often not well regulated and the no-load voltage can rise well above 12V (in your case). That's usually not a problem because it drops quickly to near 12V with any load, but it's something to keep in mind, particularly if you have something else connected to it that can't handle the higher voltage like a voltage regulator that can only handle up to 15V on its input.
Very True Mr Green but one thing about DC motor are interference or feed back to a MCU or other circuit. Below see the photo on connecting a non grounded DC motor case to prevent or cutdown on feedback spicks aka Noise control.
Jax
If a robot has a screw then it must be romoved and hacked into..
The motor in question is rated at 12 volts. I'll start with 9 volts / 1 amp... then move up to 12 volts max 3 amps. We'll see how it goes.
- Stephen
But I won't connect it to a power supply of higher than 12 volts. Only problem being, as Mike said, that you have to be careful that the un-regulated power supply does not rise above 12 volts for too long. If I need to, I'll either monitor that with a meter in the circuit, or put in a fuse / breaker.
Let me know if my understanding is off... and THANKS so much for the replies!! It's really helping.
