Help with Resetting BS2 on BOE
Ender231
Ok, I got a Gps thing for Christmas. I hooked it up to my BS2 on my BOE, and uploaded the program. Now, I want to try one that I made myself, but it says the COM3 is busy, or in use. Then it says it cannot find any BS2's attached to the PC.
Is there any way to remove the program from the BS2 without having it attached to the computer?
If not, how would I handle the situation?
2) Try reinstalling the Stamp Editor and its I/O drivers. I assume you're using the USB BOE or a BOE with a USB to serial adapter. The default drivers in Windows don't work properly.
3) You may find that it works better for now if you restart Windows. Once you reinstall the I/O drivers and restart Windows, things should work better. Also check that you have fresh batteries in your BOE power supply. The BS2 has to be powered for the PC to find it and GPS devices suck lots of power.
Merry Christmas!
