clock out phase delay
Hi Guys,
I was just wondering.· Im rigging a prop to be a LO frequency generator.· I need to "delay" or rather adjust the phase of these clocks to optimize the demodulation Im trying to do.· Im outputing frequencies ranging from 50 to 70MHz. I would like to adjust the delay of these signals.· Is this doable?
Greg
Greg
Not doing quadular on this just adjusting the delay to pic everything up on one leg. Like a lock-in amplifier. I don't know much about phase jitter, doesn't that depend on the clock used?
Also, when you change the phase shift on the fly, the correct way to do it is to increment FRQx, then decrement it by same amount. Incrementing or decrementing PHSx directly will only change its shadow register.
It looks like I need to do my homework on the counters. Just for your information Im trying to modulate a laser beam running through a fiber optic Im doing this with several beams and combining these beams together. Using a detector I can disect the beam by demodulating with the given frequency. Modulated to baseband I get the amplitude of the waveform that correlates to the phase of the laser. By doing this I can use a control loop to sync up the phase of the individual beams. Thereby having coherent light from multiple sources. I only know half of what Im doing but its fun.
Thanks for the help,
Greg
Phil,
I've gone through the counter description but haven't found a way to do the quadrature output you describe. Can you point me to more details on this?
Greg
