micro SD. are serial resisters important?
I am redesigning my propmod-us_ps_sd to make assembly easier and would like to remove the series resisters between the prop and the uSD card since this is a point were i get lots of failures(lifted traces, or shorts). Are there any reasons not to remove this?
24 bit LCD Breakout Board now in. $21.99 has backlight driver and touch sensitive decoder.
Leon
Amateur radio callsign: G1HSM
You definitely do not want them with the high speed code.
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
Leon
Leon
That could be a clue, as I think the fsrw that is needing pullups might be from nearly a year ago. Certainly the latest download seems quite different. I might drop the latest code in and see what happens...
Leon and Rayman, which code are you using - "' fsrw 2.6 Copyright 2009 Tomas Rokicki and Jonathan Dummer " or something else?
www.smarthome.viviti.com/propeller
Post Edited (Dr_Acula) : 12/24/2009 2:27:50 PM GMT
http://forums.parallax.com/showthread.php?p=862944
Perhaps I should try it with the latest software, to see if there is a problem.
Leon
Post Edited (Leon) : 12/24/2009 3:15:31 PM GMT
Leon
Nyamekye,
Leon
Nyamekye,
Bean told me that all new SD cards include internal pullups.
Leon
However, it should be mandatory that -CS be pulled high unless the card has internal pullups. This is because at least this pin will be floating until the prop runs code making this an output. This should alleviate any issues of other pins not being pulled high as the chip is disabled.
I think these will simply be vanishingly rare; I can't imagine they have separate controller chips for
SD/miniSD/microSD, especially since the adapters between these versions are just passive wire
adapters.
I think pullups on floating CMOS inputs are always a good idea (even on the prop) but maybe
that's just old-school. Perhaps the current consumed by a bouncing input these days is such a
small fraction of the total chip current that it's negligible.
Internal pullups on the SD card just make sense, though; eliminating discretes eliminates points
of failure.
I have not found any uSD cards not supporting SPI. However, I only use SanDisk. uSD and passive adapters are becoming the norm, even to other formats such as XD?? on Olympus cameras (they now come with an adapter and uSD card).
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)·
· Prop OS: SphinxOS·, PropDos , PropCmd··· Search the Propeller forums·(uses advanced Google search)
My cruising website is: ·www.bluemagic.biz·· MultiBlade Props: www.cluso.bluemagic.biz
micro sd really was the only option. I had to shave 2mil off the recommended footprint to squeeze a micro sd card slot onto my propmodules.
24 bit LCD Breakout Board now in. $24.99 has backlight driver and touch sensitive decoder.
If you have not already. Add yourself to the prophead map
