PC control of the BS2e
I have an application that needs a program written to run on a PC laptop that reads a file containing line and object drawing coordinates in inches. The program reads the endpoints of line segments (x,y) then generates the number of clock pulses for clockwise or counterclockwise commands to three stepper motors. The information sent to the BS2e is intended to match codes such as PAD0, PAD1, PAD2, etc. then read the next two words which are the·cw or ccw pulses·of the pad to be placed·on the photographic film. The machine is an x, y, z, photo plotter machine that uses three stepper motors to position the plotter head to x and y position then adjust the position of the head to make the correct line width or pad diameters.
The problem I have is writing PC code to communicate with the BS2e over the USB interface. Has anyone written or have program code to accomplish the communication from say a PC program written in Basic?
I would appreciate receiving the code.
Sincerely,
Ron Newlon
Sincerely,
Ron Newlon
- Stephen
Ron
