Awesome was waiting for this,,, prop scope blank add on boards???
Great was waiting for this , guys does anyone know if Parallax is going to offer a blank proto board for the prop scope for the 20 pin connector? I would like to buy a blank board like they have for the Hydra so we could build are own stuff for the prop scope
I think there is a lot of potential for that port.
Jim
I really want to figure out how to get my project schematics turned into real boards I went and bought Eagle Pro I can draw my schematic but that's it.. Someone should do a sticky post outlining a simple how to so we can have our own boards made I Was told it fairly inexpensive
to have a few boards made as long as they are 2 layer and not to complicated I was figuring by the time I buy blank boards and all my wire wrap supplies and wire wrap sockets I bet it would be cheaper to just have boards made and I have some really awesome designs well awesome to me lol
Post Edited (mikediv) : 12/23/2009 2:11:20 AM GMT
I am trying to whip something up in ExpressPCB right now. I·think I can get 6 proto boards out of the 3 board minimum at $51.00, (2 proto's per board with the same footprint as the Propscope DAC card.)·May be about $10 each with shipping.
I would like to add some SMT to it, so it may take a little longer.
Jim
I would love to get one so let me know if you plan on selling any I would just like a few blank cards to make up my own circuits I don't even know what I would build just looking forward I guess lol
Since this·is Hanno's software, I think it is only fair to let him reap the·good fortunes of offering add-on boards. He has done so much for the·Propeller community, it's time he got something in return.
Jim
If all you want to do is experiment, get a 26 pin (2x13) right angle make connector, and a prototyping board (like my Proteus) that will take such a connector.
Then experiment to your heart's content!
www.mikronauts.com E-mail: mikronauts _at_ gmail _dot_ com 5.0" VGA LCD in stock!
Morpheus dual Prop SBC w/ 512KB kit $119.95, Mem+2MB memory/IO kit $89.95, both kits $189.95 SerPlug $9.95
Propteus and Proteus for Propeller prototyping 6.250MHz custom Crystals run Propellers at 100MHz
Las - Large model assembler Largos - upcoming nano operating system
Parallax has done a great job with the PropScope hardware and the plan was for them to offer additional expansion cards, for example additional LSA channels. I'm busy enough supporting my various software projects, so I won't sell any add-on hardware myself. I have made good progress on the Bode plot software, but it still needs a bit more time to mature. The PropScope hardware is completely open source- David has done a good job documenting everything there. While the firmware is closed, it's easy to program the PropScope from the Propeller Tool- and the PropScope application automatically loads the firmware when it starts up.
If you want to support my work encourage others to try out 12Blocks and ViewPort! See my signature...
Hanno
Co-author of the official Propeller Guide- available at Amazon
Developer of ViewPort, the premier visual debugger for the Propeller (read the review here, thread here),
12Blocks, the block-based programming environment (thread here)
and PropScope, the multi-function USB oscilloscope/function generator/logic analyzer
Timothy D. Swieter, E.I.
www.brilldea.com - Prop Blade, LED Painter, RGB LEDs, 3.0" LCD Composite video display, eProto for SunSPOT
www.tdswieter.com
Jim
I found myself needing a fast ADC , and was thinking of putting a few channels(w-bnc) onto a propscope addon.
I never did pursue that project. I did start an Express PCB layout for a simple ProtoBoard.
It sounds like you would need a bottom up design if you where going for fast ADC, custom circuit, (separate ground planes, optimized traces, etc.).
Here's a start. You can fit 2 Propscope breakout boards on the Express PCB MiniBoard format.
Jim
A screen shot of that pcb file in your program would help me best.
Also any datasheets, schematics, data info etc would help.
Found stuff.
Schematic:
http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/PropScope_ASchematic.pdf
Code Thread:
http://forums.parallax.com/showthread.php?118621-Preliminary-documentation-for-creating-custom-PropScope-Firmware
Protocol:
Here is v0.8...
http://hannoware.com/propscope/protocol.pdf
Pdf versions:
Open Office and Inkscape format. Post #10 has the PDF versions.
Jim
Edit: I see you found them!
