Two Props One Serial Link — Parallax Forums
steprogsteprog Posts: 227
edited 2009-12-23 09:47 in Propeller 1
·Hi Guys,
Im building up a board with two props and I wanted to talk to both of them through a pc and hoped to do this with only one FDTI chip.· Is that reasonable?· Any ideals on how to do this?
Thanks Greg
  • MacGeek117MacGeek117 Posts: 747
    edited 2009-12-23 01:06
    You could have a master-slave config between the two Props ( only have the pc connected to one Prop) and use one of the cogs on the master to handle both the communication between the Props and between the master and the pc.
    Would be pretty simple with FullDuplexSerial.
    MacGeek117
    BS2: $49
    SX48 Protoboard: $10
    Propeller Protoboard: Priceless
    www.apple.com
    www.parallax.com
    www.goldmine-elec.com
    www.expresspcb.com
    www.jameco.com
    edited 2009-12-23 01:28
    The receive line from the FTDI chip could be connected to both Prop chips. You'd have to have a jumper to select which Propeller chip would transmit to the FTDI chip. On the receive end, you'd need 2.2K resistors in series with each Prop input just to play it safe if one of them were to accidentally be programmed as an output.
  • steprogsteprog Posts: 227
    Thanks for that.· I thought about tying the receive and transmitt to both, but the problem was collision with the transmit.· Actually, I probably could solve that in the code.· I.E. talking only when spoken too.
