Parallax GPS Receiver Off by 168 km
Hello,
We are using the Parallax GPS receiver with arduino.
And in setting it up and just reading raw data we found that
the lat and long is about 168 km off from our actual location.
The readings where taken outside and are consistent over
a 15 minute period of time, i.e., there is little fluctuation
in the readings. Also, the sensor was stationary.
Has anyone ever experienced this? Or have a possible
explanation of the reason?
Thanks in advance,
Adam
Post Edited (meiradam) : 12/22/2009 9:02:30 AM GMT
Thanks in advance,
Adam
Adam
If you are comparing that to a GPS reading that is Degrees, Minutes, SECONDS then you will get a large (apparent) error.
I suspect that is what is happening.
If you post the actual raw data, and your location we could tell for sure.
http://en.wikipedia.org/wiki/Geographic_coordinate_conversion
Bean.
PropBASIC home page www.propbasic.com
Post Edited (Bean (Hitt Consulting)) : 12/23/2009 5:54:49 PM GMT
$GPRMC,062842,A,3656.9344,N,12754.4580,E,000.9,000.0,221209,,,A*79
$GPGGA,062843,3656.9305,N,12754.4566,E,1,03,12.0,00000.2,M,020.5,M,,*41
$GPGSA,A,2,05,10,17,,,,,,,,,,12.0,12.0,01.0*00
$GPGSV,2,1,05,05,27,240,35,10,42,242,45,12,21,282,00,17,40,155,49*7B
$GPGSV,2,2,05,30,09,311,00,,,,,,,,,,,,*45
$GPRMC,062843,A,3656.9305,N,12754.4566,E,001.7,000.0,221209,,,A*7A
$GPGGA,062844,3656.9314,N,12754.4568,E,1,03,12.0,00000.2,M,020.5,M,,*48
$GPGSV,2,1,05,05,27,240,34,10,42,242,44,12,21,282,00,17,40,155,48*7A
$GPRMC,062844,A,3656.9314,N,12754.4568,E,001.7,000.0,221209,,,A*73
$GPGGA,062845,3656.9387,N,12754.4603,E,1,03,12.0,00000.2,M,020.5,M,,*4D
$GPGSA,A,2,05,10,17,,,,,,,,,,12.0,12.0,00.9*08
$GPGSV,2,1,05,05,27,240,33,10,42,242,45,12,21,282,00,17,40,155,48*7C
$GPRMC,062845,A,3656.9387,N,12754.4603,E,001.7,000.0,221209,,,A*76
Our location should be in Chungju, South Korea: 36.949945N, 127.907371K
I will look into the minutes/seconds issue and see if that resolves the problem.
Adam
Adam
GPS: DDMM.mmmm and DDDMM.mmmm (Degrees, Minutes & decimal Minutes)
Your comparison: DD.dddddd· and· DDD.dddddd (Degrees & decimal Degrees)
Converting the GPS's notation to your data notation·gives:
56.9305 / 60 = .948841· and 54.4566 /60 = .907610
36.948841 N· 127.907610 E
That's a lot less than 168 km difference (~0.12 km of LAT).
Duffer
Powered by enthusiasm
Adam
I ran into the same thing trying to use the Parallax GPS coordinates in Google Earth (I think).
Bean.
