Propeller-based security system: long-distance programming ? — Parallax Forums
Greg PGreg P Posts: 58
edited 2009-12-22 17:10 in Propeller 1
I would like to retrofit my father's security system using a Propeller-based circuit (as a Christmas gift). The existing 25-year old system has been experiencing frequent false alarms. Attempts to isolate the defective window or door sensor have proven unsuccessful. The sensors are wired in series and more than one sensor is likely defective so debugging is difficult at best. If I use a Propeller to wire all door/window sensors in parallel to individual Propeller i/o pins I can both diagnosis which sensors are defective and add an additional layer of intelligence to the system. For example, the alarm system could be programmed to ignore sensor activation if not accompanied by activation of other sensors within a prescribed time frame.
My questions:
1) I would like to give him the ability to edit Propeller code from his own PC. Unfortunately, to connect the Propeller circuit (located in his basement near the alarm system) to his PC (two floors above), I must route the PC RS232 signal through existing wires to his attic then to the basement ... upwards of 250 feet !! While I know I can communicate with the Propeller at low 9600 baud rates reliably at this distance, I don't know if it would be possible to upload new firmware to the Propeller (and its EEprom) using the Propeller Tool software from such a great distance. Does anyone in the Propeller community know if the Propeller Tool is capable of long-distance uploading of new firmware ? If not, is there a work-around solution ? He does not have a portable PC so that eliminates one possibility. Could I program an additional Propeller to receive the "firmware code" via RS232 at 9600 baud, stored it internally, then have it program a second nearby Propeller which will actually be communicating with the old alarm system ?
2) Does anyone have a suggestion on how best to protect the input signals to the Propeller from lightning damage ? I will be using a fairly large value (100K) current limiting resistor, but is there a cheap fast acting bidirectional voltage limiting component I could add as well ?
Any help with these two question would be greatly appreciated ... especially the first.
    edited 2009-12-21 00:35
    For litning only optical coupling will work and you need a chunk of fiberoptic cable not an opto isolator ic.
    For programming you can add an sd card and use my bootloader in the obex.
    24 bit LCD Breakout Board now in. $21.99 has backlight driver and touch sensitive decoder.
  • T ChapT Chap Posts: 4,260
    edited 2009-12-21 00:54
    You don't have to use the Prop Tool or other IDE for updating the program. You have a number of other options, including using USB or SD as was just mentioned. First off for those distances you need RS485. See MAX485 or MAX 3430(3V3 supply needed). These are very easy to attach to the Prop, and you can use CAT5e or CAT6 cable. To update firmware from a distance without using the Prop Tool or BST (F10, F11), you can create your own app that transfers the bytes of the compiled .eeprom file to the Prop in little chuncks, I use 64byte per each writepage, but 128 is possible. You transfer the bytes to the EEPROM, then reboot the prop after the transfer. I am working on an app that does this exact thing for this purpose.
    Your best bet for remote reprogramming is a standalone app that transfers the byte from the PC to the Prop. You would need a method in the Prop to receive the chunks, and write them to the EEPROM as they come in. I recommend Real Basic for putting together such a stand alone app.
    If you have the ability to get to the unit without a problem, you can get a VMUSIC2 or VDIP, and attach it to the Prop. You then could compile the program into a .eeprom file, drag it to the USBdrive, take the drive to the Prop and VDIP or VMUSIC2, plug it in and run a method on the PRop to update the firmware. As mctrivia just stated, you can also use the SD cards for updating.
    Post Edited (Todd Chapman) : 12/21/2009 1:07:19 AM GMT
  • SRLMSRLM Posts: 5,045
    edited 2009-12-21 02:27
    To program "remotely" you could also build the setup with DIP EEPROMS in sockets, and simply program a Propeller at the computer, remove the EEPROM, and plug it into the security system. It has the advantage of being reliable and easy...
    Powered by enthusiasm
  • Greg PGreg P Posts: 58
    edited 2009-12-21 02:56
    From the following web site:
    www.lammertbies.nl/comm/info/RS-232_specs.html
    The cable length mentioned in the standard allows maximum communication speed to occur. If speed is reduced by a factor 2 or 4, the maximum length increases dramatically. Texas Instruments has done some practical experiments years ago at different baud rates to test the maximum allowed cable lengths. Keep in mind, that the RS232 standard was originally developed for 20 kbps. By halving the maximum communication speed, the allowed cable length increases a factor ten!
    RS232 cable length according to Texas Instruments
    Baud rate Maximum cable length (ft)
    19200 50
    9600 500
    4800 1000
    2400 3000
    The numbers above give me confidence that RS232 will work (with lightning protection). Also, note that serial Propeller code simply samples data at mid bit position. Any additional cable capacitance would tend to eliminate transients, the better for reliable detection. Only initial edge detection of the start bit would seem to be a concern.
    Also, I have been looking at Chip's Propeller Loader v1.0 object. He provides a means of programming one Propeller from another Propeller. If the "programmer" propeller could be equipped with a serial object, it could simply copy incoming low-baud (<9600) data to hub ram then using the loader object program the "alarm system" Propeller. I could write a simple PC application that would send the contents of the .eeprom file, perhaps appending a checksum for confidence.
    It would be nice if after the upload operation, the "programmer" propeller could revert to a default "relay station" for transferring low baud data back and forth from the "alarm system" propeller. This suggests that the "programmer" propeller should accept a special "P" programming command from the PC, but otherwise simply pass through data back and forth to the "alarm system" propeller.
    Does anyone have existing code which performs this function ?
    edited 2009-12-21 03:06
    Also,
    My father is disabled, so walking two stories up and down stairs to swap out SD cards would be difficult for him. The programming serial cable would normally be disconnected except for rare firmware updating operations ... reducing the risk of lightning damage. But while testing the new code, as you know, multiple uploads may be required in a short period of time.
    edited 2009-12-21 03:27
    You can most definately do what you require, provided you can communicate·reliably over the distance.
    There are objects to do what you require in the OBEX as you have discovered. I am assuming that you have a cog capable of communication serially, with the appropriate interface (RS232 is the easiest, although RS485 may be better for you situation).
    Anyway, you will require a cog with serial comms and a cog to check the code received is valid.
    There are OBEX objects that will program the eeprom. If you use a 64KB eeprom (AT24C512B) you will be able to program the upper 32KB as it is received. If successfully received (using checksum) then after it is programmed in the upper 32KB, copy to the lower 32KB and reboot - you can see examples of this in PropDos and Femtobasic.
    As for lightening strikes, nothing is foolproof here.
    What I used to do in modem designs was to have·series resistors (3-5 ohms 1/4W or less) and MOV's accross the leads after the series resistors. What happens is that an overvoltage will cause the MOV to activate and the resistor will blow. Usually, you just replace the resistors, so socketing them can be appropriate. Note I have still seen modems destroyed, but most were protected by this method. Strikes are usually > 7KV.
    · Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
    · Search the Propeller forums·(uses advanced Google search)
    edited 2009-12-21 03:49
    So, does the Propeller Loader or EEprom programmers require a full 32K bytes be transmitted ? In the case of the Propeller Loader example by Chip, the inserted binary file must of necessity be less the total 32K bytes to fit in the "programming" propeller. That suggests that if my code for the destination "alarm system" propeller is somewhat less than 32K bytes (so that the full code will fit in the "programmer' propeller hub memory) I should be able to send using the Propeller Loader a quantity of data less than 32K bytes.
    My objective is to avoid using more than 32K byte eeprom so that I can purchase one of the pre-assembled development boards.
    Is this correct ? If not, please clarify. Thanks !
    edited 2009-12-21 04:01
    Greg, you will need to add drivers to the prop and a USB - serial adapter of some sort to the PC unless it is an old unit with RS232. Using RS485 drivers is no more difficult than using RS232 drivers and they give you much higher speeds. I have installed equipment using RS485 that reliably communicates at 115Kb/s over a distance of 500 feet.
    PS - The standard RS232 protocol can still be used with RS485 drivers/receivers.
  • VIRANDVIRAND Posts: 656
    edited 2009-12-21 07:44
    Somebody at TI said...
    19200 50
    9600 500
    4800 1000
    2400 3000
    Who makes this stuff up? I swear, the correct unit is MILES NOT FEET.
    Who has DSL, and needs signal boosters every 25 feet?
    Does the phone company boost their trunk lines every 50 feet?
    Post Edited (VIRAND) : 12/21/2009 8:12:03 AM GMT
    edited 2009-12-21 08:41
    Some prop boards have 64KB eeproms, but not all.
    Only the required (used) section of the 32KB is actually loaded and the balance is zero filled by the prop object. You will need to check the object you intend using.
    Should you stop the alarm code, then you could manage a different mechanism.
    RS232 and RS485 are only electrical interfaces. The underlying software interface is now usually serial (asynchronous) although that was not always the case.
  • Andrey DemenevAndrey Demenev Posts: 386
    edited 2009-12-21 09:14
    I have been using Bluetooth module to remotely reprogram AVR micros. The same can be done with propeller. Bluetooth, possibly, is not very reliable at such long distance, but 433 MHz serial RF modules would work, I think.
    PRO: no wires.
    CONTRA: propeller tool would not work, since there is no means to trigger reset line via RF module. A special program would be needed. Greg, unfortunately, I do not use Windows anymore, and cannot help you with such a program.
  • hippyhippy Posts: 1,981
    edited 2009-12-21 13:10
    VIRAND said...
    19200 50
    9600 500
    4800 1000
    2400 3000
    The Texas Instruments tests were done on specific cable with particular characteristics ( particularly capacitance ) to determine when the signal was fully compliant with the RS232C ( or whatever ) specification. There is no reason to believe it is either made up or not correct. AFAIR they state that change the characteristics and maximum distance changes.
    VIRAND said...
    DSL is not RS232C.
    I've sent DMX-512 at 250,000 baud over 1km on three-core mains cable using RS485. That's not RS232C either.
  • Jay KickliterJay Kickliter Posts: 446
    edited 2009-12-21 14:39
    Why not do this wirelessly? A couple XBee's, and some way to get that data into a storage device, with a bootloader is possible. Not necessarily easy though.
    edited 2009-12-21 15:56
    Thanks for the RS485 suggestion !
    I located an in-stock, $1.66, 8-pin DIP RS485 transceiver chip which affords live insert/removal, immunity from ESD & latchup, 4000 ft operation at 110Khz, low 300uA power consumption, and tolerance for up to +/-7v differential in transceiver grounds !!!
    If I were to use three of these chips for the TX, RX, and RESET lines, I believe I could directly program the "alarm system" Propeller chip located +250 feet away from my Dad's PC. He has available an "old fashioned" RS232 9-pin port on his PC. I would just need to furnish a local +5v supply for powering a circuit with three LTC485 chips and an RS-232-to-TTL translation chip (like a MAX233).
    Taking this approach eliminates the need to perform extra steps when uploading new firmware. No saving of eeprom binary files, writing a special uploader program, etc. !
    A great bonus: the same TX & RX serial lines could be used by my Propeller application to send status information back to the PC !
    What do you guys think .... will this approach work ? Thanks for your many suggestions.
    search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=LTC485CN8%23PBF-ND
    Digi-Key Part Number LTC485CN8#PBF-ND (8-pin DIP, 5v supply )
    Quantity Available 3,654
    25 Piece Pricing $1.66 each
    Previous RS485 transceivers have been designed using bipolar technology because the common mode range of the device must extend beyond the supplies and the device must be immune to ESD damage and latchup. Unfortunately, the bipolar devices draw a large amount of supply current, which is unacceptable for the numerous applications that require low power consumption. The LTC485 is the first CMOS RS485/RS422 transceiver which features ultralow power consumption without sacrificing ESD and latchup immunity.
    @ LTC485 is able to comfortably drive 4000 feet of wire at 110kHz.
    @ 30ns Typical Driver Propagation Delays with 5ns Skew for Up to 2.5MB Operation
    @ Power-Up/Down Glitch-Free Driver Outputs Permit Live Insertion or Removal of Transceiver
    @ –7V to 12V Bus Common Mode Range Permits 7V Ground Difference Between Devices on the Bus
    @ Low Power: ICC = 300uA Typ
    Post Edited (Greg P) : 12/21/2009 4:02:36 PM GMT
  • cocokiwicocokiwi Posts: 75
    edited 2009-12-21 16:53
    VIRAND said...
    19200 50
    9600 500
    4800 1000
    2400 3000
    WRONG!!
    You don,t know anything about DSL.. DSL and Cable Co use a similar format The signal is NOT sent via a wire pair
    like the phone or coax Cable tv! the signal is an RF signal which is sent as an overlay on the wire which don,t affect the phone calls.
    And DSL dies off as you get further away,most one gets back in the earlier day,s was about a mile before it started to get real bad,ADSL was better but expensive.
    now it's improved a lot, I think they solved the problem with how far with fiber optics ,run to a box close to home,the cable Co do it now,I get 20 + meg bps now!
    Back when, I was using a 300 baud modem, back in 83 on my old Coco, them were the day's...26 year's,our Prop chip maker(Chip) should know He had one too smhair.gif
    kind of like what we are doing with the Prop chip these day's.
    Merry Xmas and to ALL a happy new year
    Cheer's Dennis
    http://people.delphiforums.com/cocokiwi/Image/picture.jpg
    edited 2009-12-21 19:44
    Greg: The LTC485 sounds like it will do your job nicely. Place the transistor & rc circuitry at the prop end as this generates a short reset pulse.
    You should then be able to download and communicate nicely using TXD, RXD & DTR.
    The only caveat on all this is providing the wiring is 'quiet' from interference.
    As you mentioned lightening strikes, are these likely in your area. If so, I suggest using the resistors and movs at both ends.
    edited 2009-12-21 23:30
    I am not trying to start a flame war.
    Re:cocowiki
    There is, in my experience, no un-obvious behavior whatsoever in wire at Low Frequencies.
    Anyone who has electricity and a telephone mostly knows how wires work at LF.
    An exception is Tesla Coils, which are made of wire and behave very strangely.
    To RF, radio frequencies, wire is mostly like an antenna. For microwaves and Light, wire is mostly useless.
    The Propeller may be the first common user-programmable device that almost steps over the limits of
    obvious wire behavior, and I am only talking about its ability to broadcast video and receive AM radio
    by using software, and these kinds of things. A 6502 is capable of high speed RS-232 and standard speed i2c
    over long distances with software.
    I have seen DSL over an ordinary telephone wire, split to a phone and a modem with a crossover filter,
    and followed the telephone wire (one twisted pair) to a neighborhood phone box with No electronics inside,
    but only a "block" that crimps together twisted pairs from homes, to ones from a thick bundle of them
    which goes directly to the local central exchange. I have seen the DSL signal on an oscilloscope. It doesn't
    really look like anything else but noise. I was shown this by a telephone company man within the last 9
    years, who STILL does not know how to install fiber. I have rarely seen fiber, in fact only in a public
    school network. This is within 100 miles of New York City, and I doubt that there is any fiber (in that
    suburban town where the telephone man lives) outside of the Public School at all! The town does have public wifi though.
    edited 2009-12-22 01:58
    VIRAND, there are reasons RS232 has such a poor range compared to other standards. It was designed to connect text terminals and printers to computers so short cable lengths and low speeds were not a problem.
    RS232 uses a single line for transmit and one for receive, with both signals referenced to a ground wire. That makes it more susceptible to noise pickup. It is also a voltage level (+-12V nominal) and the transmitter/receiver are fairly high impedance which makes noise even more of a problem. The standard also does not require twisted pair cables although they are used often now.
    RS 422/485 is a 2 wire twisted pair with differential signalling so when one wire goes low the other goes high. The receiver is looking at the difference between the two signals, not an absolute voltage level. Any noise pickup appears on both lines and is canceled by the receiver since it is looking at the difference between the lines, not the absolute levels.
    DSL is also a differential signal with data modulated on a high frequency carrier and sent over the twisted pair phone line. A filter separates the high frequency from the audio so a single twisted pair can carry both data and voice. I am sure there is a limit on how far it can be sent (2-5 miles I think) since I could not get DSL in my previous house because we were too far from the exchange.
    edited 2009-12-22 11:28
    @ALL:I'm very sorry for (if I am doing so) hijacking the thread.
    Re:kwinn
    If I run a wire from here to your house, and lets assume we each have our own pairs,
    and I am sending data with one wire connected to digital ground and the other wire was going positive and negative in voltage,
    and you are sending data using differential signals, with a second gate outputting just the other one inverted.
    In that case, if we were ignorant of each other's outputs, how could we tell the difference?
    Both of us would see relative polarity reversals on each wire pair.
    It seems likely that each other's wire pairs would pick up almost equal amounts of noise that would cancel.
    If there is a way to tell, an op-amp or two should prevent or remove that information.
    If you can get the Propeller to transmit GRAPHICS to an ANALOG TV channel... WIRELESS-ly... (Challenging)
    Then you can get it to transmit much further with a wire pair directly connected.
    If it seems otherwise, try shunting the TV end of the wires with a 100 ohm resistor. (or use a balun)
    That will make the Very High Frequency want to go to the end of the wire more than jumping off into space.
    NO, DON'T DO THIS EXPERIMENT ON HDTV. STILL GOT THE OLD TUBE?
    If you succeed, realize you are putting more than the equivalent of over 54Mbps of simple serial data through a wire.
    Yes, I know, the TV only uses 4 to 6 Mhz of it, but the Propeller might make over 60 MHz go through a lot of wire.
    VIRAND, you cannot really compare a TV transmission to serial communication. The video signal modulates an RF carrier and the TV set has some very sophisticated circuitry to separate the desired signal, amplify it to the correct level, and demodulate it for display. RS232, 422, and 485 are baseband signals, and the transmitters are basically level shifters, receivers basically voltage comparators.
    Check out http://en.wikipedia.org/wiki/EIA-485 and look at the "See Also" section for RS232 and some of the other protocols. I have worked with serial protocols (RS232, RS422, RS423, RS485, and others) for many years and the limitations of RS232 are real. Under ideal circumstances the speeds and distances attainable may be greater than the specs, but in the real world they are reasonable limitations if you want a reliable system.
