MAX6955 package confusion...
Hi all,
I recently picked up a MAX6955 LED display driver and am trying to i/f with my Propeller (hence making this post on-topic!). However I am mightily confused by the packaging vs. specs of this IC... I have in my hands a 40-pin DIP package, but the spec sheet describes a 36-pin package that looks like a DIP but is labelled something else, and a 40-pin square surface-mount package that is clearly not the droid I'm looking for...
I'm lost. Am I supposed to be working with one of the two pinouts below, or something completely different!?!
Edit: Photo of chip attached.
Post Edited (Nak) : 12/20/2009 1:43:52 AM GMT
Jim
Post Edited (hover1) : 12/20/2009 1:14:18 AM GMT
PS: Is there a safe way to probe at the pins of an IC and tell if they're not connected to anything?
I'm not understanding what you are asking. You would connect the pins of the Max device to the correct pins on the Propeller Chip.
You have not·attached a schematic or PCB layout·that I think you might be refering to.
Jim
