Photointerruptor Identification Help... :(
Hi-
I've got a photointerruptor labelled K-2212, 5301-01 and 8301. Inside are identical-looking LED packages, one clear, one smoky gray. Which one's which? I can't seem to find a datasheet for this...anyone have any ideas?
Raf
UC Berkeley '12 EECS
CalSol: Berkeley Solar Car team
www.calsol.berkeley.edu
KJ6AWU
Raf
KJ6AWU
Raf
KJ6AWU
Out of all the 8 possibilities (which one being measured, polarity of each) only one comes close to making any sense. In this position, when it's interrupted, my Prop reports consistent "LOW", when it's not, it alternates between low and high about every half a second. In any other setup but two, the same pulsing happens independent of the position of the sensor. The last two setups always remain high. What do I have here??
Raf
KJ6AWU
KJ6AWU
- Stephen
The Prop can directly read the detector as a digital input. It's connected to 3.3V through about 5k which gives about 2V when the sensor is not interrupted and 0V when it is.
Works great[noparse]:)[/noparse] Now to find out how fast of things I can actually measure...
KJ6AWU
