Parallax Serial Terminal in Linux
I am trying to run the PST Debugger under WINE on my Ubuntu 9.10 machine through the serial port.
I would like to know if anyone on the forums using Linux was able to use this program, and how did they do it?
I have combed the Wine-hq.org site trying to find an answer: I believed it has to do with how Wine configures the serial ports and how the programs interact with them. I configured the /dev/ttys0 as they stated here: www.winehq.org/docs/wineusr-guide/misc-things-to-configure, but to avail.
I was just wondering if anyone has given this a shot and it came out working.
Post Edited (tdeyle) : 12/18/2009 4:42:20 PM GMT
The Propeller Tool, Propellent, and Parallax Serial Terminal all use the same API calls to use the com port. As far as I understand, WINE does not support some of these APIs. BradC was able to get the Propeller Tool working under WINE, but as of version 1.0.1, it does not look like his patches have been integrated.
-- David Carrier
Someone was kind enough to write a post with a link to their blog on how to successfully set up the serial ports.
This has worked for me. I would suggest giving it a try: Link
I had the trial version of viewport running under linux, initially, without serial port recognition. Unfortunately, I was past the 30 day trial limit when wine was configured correctly and can't comment on its performance yet.
<EDIT>
I actually do have that version. But, I am using the serial port, not the USB. I think this is why it did not work. I saw in the BST threads that they are having trouble with Ubuntu 9.10 recognizing FTDI chips. I don't have one, I have a USB to Serial Converter with a Prolific chip. Supposedly, the drivers are included with the 2.6+ kernel. But... it still isn't working.
I even tried Sun's VirtualBox with an XP install: no dice. When there is a repeat loop in the SPIN program, the VB crashes.
I'll try reinstalling Wine and see if that cures it.
Looks like I won't get any sleep tonight!
Post Edited (tdeyle) : 12/18/2009 9:31:53 PM GMT
propeller.wikispaces.com/Mac+and+Linux+native+development
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
And.. it looks like I will be getting some sleep after all! It turns out that the Wine version that the Ubuntu repository has is 1.1.34. I was removed it, then installed it again, this time forcing that revision 1.0.1.
I relaunched the Parallax Serial Terminal, reloaded the Propeller with the PST Debugger Demo in BST and bam! It worked!
Thanks AJM, for mentioning that link again!
I also use BST pretty much exclusively. In this case I feel the effort is worth it, especially if the propscope works under linux. I can't see why it wouldn't. Some day I will have to order one.
