PT1000 Temperature sensors
I would like to use a PT1000 temperature sensor with my controller but I'm not really sure how to do that.
PT1000 resistance will vary based on the temperature. I would like to convert the resistance to a frequency so I can ready from the controller. Any clue how I cool do that?
Or maybe it's not a good way and I'm better to read that differently?
I really want to keep this sensor because it can up to +200C.
All the help will be welcome.
JM
JM
If you want higher precision and you're willing to use a more complex circuit, you could use an LM331 voltage to frequency converter or a 555 timer in asynchronous mode. With the LM331, you'd have the pulse frequency related to the resistance. With the 555 timer, the pulse width would be related to the resistance. A Stamp would use the COUNT statement for the LM331 or the PULSIN statement for the 555. Again, refer to the Manual for details.
Thanks for your reply. I did not figured that controller can be a variable on this equation.
I'm using a Javelin.
But following your recommation for newbee (RTFM), I was able to find, page 55/56/169, exactly what I was looking for [noparse]:)[/noparse] Thanks to you for providing the RCTIME keyword. That's what I used to find that.
So I will do some testing with rcTime() and see how I can use that with my sensor.
Thanks again,
JM
