Problem with Serial Converter Code
I am having problems with the attached Basic Stamp 2·code. The program inputs a serial string, and then based on the string, outputs a different string. The problem I am having is that is takes two serial strings to make the Case Select code work. When I put in a Debug statement and the Debug window opens up, I notice that the RX Led on the Debug interface only·flashes when a second string is received. It does not flash when only a single string is input.
What are the exact bytes being sent by the originating device? I ask because since you're using both a WAIT and HEX modifier, several things need to happen exactly to meet both conditions. It would help to know exactly what bytes are being sent to the BS2.
Parallax Engineering
Check out the new Savage Circuits TV!
