Using Arrays when Expanding I/Os
I currently have 16 inputs and 16 outputs (using the expanding inputs and expanding outputs code from the parallax examples) coming off of a BS2p module. Here is my problem.
What I want my program to do:
I want to be able to go to a subroutine the displays "Male Limit Pressed" when the first button is pressed regardless of whether or not the other buttons are pressed.
What it currently does:
I can see when each button is press (via the DEBUG "Switches = ", bin8 Trigger, CR line) but the program never goes to the subroutine.
What I think I have (but I've never worked with arrays before) is each individual bit of the array (Triggers) put into Switches as the input variables. Is that right? I'm kind of stuck, I've tried everything I can think of and looked at several different websites. Am I on the right track? What am I doing wrong that is preventing the program to go to the subroutine? My code is below.
-Tara
' {$STAMP BS2p}
' {$PBASIC 2.5}
' File......Array Test.bs2
' Purpose...To test the Array function with the expanding Inputs and Outputs
' Started...12/11/09
' Updated...12/15/09
' -----[noparse][[/noparse] Program Description ]---------------------------------------------
'When the first "switch" is pressed (MaleLimit), the program will say "Male
'Limit Pressed" and stop.
' -----[noparse][[/noparse] Revision History ]------------------------------------------------
' -----[noparse][[/noparse] I/O Definitions ]-------------------------------------------------
Clock CON 15 ' shift clock (74x165.2)
DataOut CON 14 ' serial data out (74HC595.14)
Latch CON 13 ' output latch (74HC595.12)
DataIn CON 12 ' shift data (74x165.7)
Load CON 11 ' input load (74x165.1)
' -----[noparse][[/noparse] Constants ]-------------------------------------------------------
' -----[noparse][[/noparse] Variables ]-------------------------------------------------------
n VAR Nib
Triggers VAR Byte(8)
MaleLimit VAR Bit
FemaleLimit VAR Bit
ScooperLimit VAR Bit
ScooperTrigger VAR Bit
DispenserTrigger VAR Bit
AirCylinderTrigger VAR Bit
MaleTabs VAR Bit
FemaleTabs VAR Bit
switches VAR Byte ' inputs switches
buttons VAR Byte ' push button inputs
pattern VAR Byte ' output pattern
counter VAR Byte
MaleLimit = Triggers(0)
FemaleLimit = Triggers(1)
ScooperLimit = Triggers(2)
ScooperTrigger = Triggers(3)
DispenserTrigger = Triggers(4)
AirCylinderTrigger = Triggers(5)
MaleTabs = Triggers(6)
FemaleTabs = Triggers(7)
' -----[noparse][[/noparse] EEPROM Data ]-----------------------------------------------------
' -----[noparse][[/noparse] Initialization ]--------------------------------------------------
Initialize:
LOW Latch ' make output and keep low
pattern = %11111111
counter = %00000000
HIGH Load ' make output; initialize to 1
' -----[noparse][[/noparse] Program Code ]----------------------------------------------------
main:
GOSUB Read_165 ' read switches and buttons
IF (MaleLimit = 1) THEN GOTO here
FOR n = 0 TO 7
Triggers(n) = switches
switches = switches >> 1
GOSUB Out_595
PAUSE 20
NEXT
DEBUG "Swithces = ", BIN8 Triggers, CR
PAUSE 20
GOTO main
' -----[noparse][[/noparse] Subroutines ]-----------------------------------------------------
Read_165:
PULSOUT Load, 5 ' latch inputs
SHIFTIN DataIn, Clock, MSBPRE, [noparse][[/noparse]buttons] ' get buttons
SHIFTIN DataIn, Clock, MSBPRE, [noparse][[/noparse]switches] ' get switches
RETURN
Out_595:
SHIFTOUT DataOut, Clock, MSBFIRST, [noparse][[/noparse]counter] ' send counter to 2nd 74HC595
SHIFTOUT DataOut, Clock, MSBFIRST, [noparse][[/noparse]pattern] ' send pattern to 1st 74HC595
PULSOUT Latch, 5 ' latch outputs
RETURN
here:
DEBUG "Male Limit Pressed", CR
pattern = %00000000
counter = %11111111
GOSUB Out_595
PAUSE 1000
END
-Tara
In your code when you read the shift-registers your data is in the variables buttons and switches. Immediately after the read you’re testing for MaleLimit to equal 1 but that variable has not been set. It seems you’re trying to alias an array but the data isn’t in the array at this point. From looking at the FOR…NEXT loop following I would recommend instead to test for the bit you’re looking for. For example:
IF buttons.BIT3 = 1 THEN …
Also, it is better to attach full programs…trying to follow a full program pasted into the message is difficult at best. Attaching it allows it to be easily loaded into the editor with all formatting intact. Take care.
Parallax Engineering
Check out the new Savage Circuits TV!
I have also tried putting those two lines (GOSUB Read_165 ' read switches and buttons; IF (MaleLimit = 1) THEN GOTO here) below the FOR...NEXT loop and I get the same result. I have also tried it using
If buttons.BIT0 =1 THEN GOTO here
and again I get the same results. I have attached my code. Is there anything else I can try?
-Tara
...where variable is either buttons or switches depending on which shift-register you're connected to.· Remember, the first one in the chain goes into buttons and the last one goes into switches.· I hope this helps.· Take care.
Post Edited (Chris Savage (Parallax)) : 12/15/2009 6:31:54 PM GMT
If it helps, I have everything set up as described in www.parallax.com/dl/docs/books/sw/exp/sw23b.pdf and www.parallax.com/dl/docs/books/sw/exp/sw24b.pdf.
-Tara
Post Edited (RGR_Engineer) : 12/15/2009 6:52:59 PM GMT
-Tara
[/code][/size]
instead of
But now the line:
no longer displays the pressing of the buttons. Instead I get all 0s.
Even when I do this:
I'm not sure why the display is wrong now that the button is working correctly.
-Tara
-Tara
Example:
I have input variables (the ones listed in my above post) and output variable
I want to Toggle the value of the MaleRev (Motors.BIT4) when MaleLimit (Triggers.BIT0) is pressed.
My code is attached.
-Tara
-Tara
