Propeller Tool issue — Parallax Forums
UntelUntel Posts: 27
edited 2009-12-15 23:11 in Propeller 1
This topic was sent last week and it is no longer present on the forum ???
Closing Propeller Tool using the [noparse][[/noparse]X] windows button does close the Propeller tool but does not terminate the application.
Using the Windows Task mamager shows that it is still running and slow down the process.
I got one answer from a member telling me that this is not the only issue with Propeller Tool.
Just wonder if any one at Parallax will care enough to giving me any kind of answer on this.
Regards
  • RaymanRayman Posts: 16,385
    edited 2009-12-15 16:37
    I just tried at and don't see it in Task Manager...
    Does it happen every time for you?
    What version of PropTool ?
    Which Windows?
  • UntelUntel Posts: 27
    edited 2009-12-15 16:47
    Version 1.2.7 and precedent version of the tool will give this issue on every closure using the [noparse][[/noparse]X] button
    I ham running Propeller tool on Vista Pro.
    Tanks helping!
    edited 2009-12-15 16:59
    Untel said...
    Try This:
    http://forums.parallax.com/showthread.php?p=863027
  • tdlivingstdlivings Posts: 437
    edited 2009-12-15 17:18
    Windows 7, Propeller Tool 1.27 closes·using the x fine.
    Parallax Serial Terminal also closes using the x fine
    No trace in Task Manager.
    I tried running multiple copies of Propeller Tool and did not
    see more than one in Task Manager but did get an access
    violation dialog pop up while looking at Task Manager. Upon
    closing Task Manager and then using the x to close Propeller
    Tool I see no sign of Propeller Tool in Task Manager.
    Tom
  • LeonLeon Posts: 7,620
    edited 2009-12-15 17:26
    It sort of crashes every time I close it. I didn't know there was a version 1.2.7, I'll try that.
    1.2.7 seems to have fixed the problem.
    Leon
    Amateur radio callsign: G1HSM
    Post Edited (Leon) : 12/15/2009 5:45:09 PM GMT
    edited 2009-12-15 19:07
    There is no problem if you close Propeller Tool just after openinig it. I got this issue after using it for a while.
  • Jeff MartinJeff Martin Posts: 762
    edited 2009-12-15 22:40
    We are aware of this problem and trying to solve it. It seems to happen a lot on some systems and not at all on others. We've been collecting bug reports from this for quite a while to narrow it down as it seems to be related to an invalid pointer created by processing Windows messages in a different order than intended. We are working on this and many other fixes and enhancements and will release as soon as possible. The readme notes will mention the correction of this bug with words like "fixed exception error that can occur upon closing..."
    --Jeff Martin
    · Sr. Software Engineer
    · Parallax, Inc.
    edited 2009-12-15 23:06
    I occasionally will get an exception error on exit from the PropTool. I'm using Vista Ultimate 64 on one machine and Windows 7 Pro 64 on the other machine. It definately seems to be related to how long I've had the tool open and how much I have done in the tool. It never happens if I have a short session.
    Check out the Propeller Wiki·and contribute if you can.
  • KyeKye Posts: 2,200
    I get this error too alot. It seems harmless but is rather annoying.
    Nyamekye,
