How is smart????
please please help me for my project ....
i work with Boe-Bot and the project is to use ultrasonic sensor"ping" to avoid obestacle
so please what is the code that will help me to do this???the program that i used is the Basic Stamp2??
please help me as soon as possible
Parallax Engineering
Check out the new Savage Circuits TV!
i download the code but theres some parts i didnt understand it??
PingServo PIN 14 ' PING))) Servo
what is the job of the ping servo did i need it since i connect the Ping directly to the board of education.
the Dr. ask us also to put compass and 433 MHz RF Transmitter along with the ultrasonic"Ping"? i connect all these component using the datasheet for all of them.but the problem that i face is to write acode that combine all these devices??
so if you can advice me please help.
You will have to learn enough Basic to modify the various sample programs to do what you want with the compass and RF transmitter. There are no ready-made programs that use these. This is a project for a course and part of the purpose of the course is to learn how to program and to learn how to modify and combine pieces of other programs to do what you want. We cannot do that for you. I suggest starting with the various introductory tutorials on the Stamp, "What's a Microcontroller?", "Robotics with the BoeBot", and "BASIC Stamp Syntax and Reference Manual". You might also have a discussion with your professor about your confusion and see if your professor has any other suggestions.
Part of the design process is to decide what you want the various parts to do and to document your plan thoroughly. It helps to write down a series of rules ... "If this is true, then do that." or "If the PING detects an object closer than 10cm, then turn the BoeBot to the right approximately 90 degrees using the compass and go back to the main loop." Then you have a guide for what sort of programming changes you need to make.
