Pic Knowledge needed
i have just completed an assembly project for a customer that involved the use of a pic18fxxxx. I installed all of the PICs onto the boards (in sockets as the customer requested) only to find that the PICs still need to be programmed. Does anyone know if i use a clip to contact the pic in circuit, can it be programmed? Any advice would be great. otherwise we will just give it a try. Thanks again
It's Only A Stupid Question If You Have Not Googled It First!!
It depends on how the pins that are used for programming are connected. Also, when you power the chip in-circuit to be programmed, you will power up the whole board, which may have consequences for your voltage regulator if Vdd is clipped directly to the PIC. Most MIcrochip PIC datasheets include a schematic with recommended pin connections to use when in-circuit programming is necessary (i.e. series resistors, protection from high Vpp, etc.). If your board follows these guidelines, you should be okay; otherwise, you'll probably have to unsocket the PICs and program them externally.
Mike2545
