Newbie question about starting new cogs
I have several objects that need to be operated all at the same time. How do I simply load the other objects, from within the top object, into new cogs and let them do there thing?
Working on getting money for autopilot project. Come check out my site if your interested in the project. Maybe go to the bottom of the page
www.parallax.com/Portals/0/Downloads/docs/prod/prop/PELabsFunBook-v1.1.pdf
Information about using Objects follows the aforementioned section.
Also, you can read about the Cognew command in the Propeller Manual
www.parallax.com/Portals/0/Downloads/docs/prod/prop/WebPM-v1.1.pdf
Also, you can take a look at Example 3 on this:
http://forums.parallax.com/showthread.php?p=574524
Post Edited (ElectricAye) : 12/15/2009 3:33:14 AM GMT
·· The following code snippet gets all 8 cogs running methods in the·current object
/michael·
