SD card write speed
Hello,
I'm new to the propeller. I see alot of info about using a SD card with the propeller.
At this point I don't have any specific code or application to post.
1. Say I'm using the SD card to record data through an ADC. I want to read 10 channels, each one 10 times per second. Can I write to the SD card fast enough to keep up with this?
2. I'd like to import this data into an excel spreadsheet. The data has to be saved in a certain format to be read by excel? This is where My understanding gets a little fuzzy. What do I need to do to save this data in the correct format?
Thanks for any help,
Alex
If at first you don't succeed, then skydiving is not for you.
Alex
2. I would use comma delimited data eg. 1,2,3.56,4.56 since Excel excepts this format. You'll have to use Floatstring to convert the raw data to ascii.· Also you should buffer your incoming data since the conversion to Ascii will be slower than your sampling rate.
Will work for Propeller parts!
Jonathan
lonesock
Piranha are people too.
about 2.) Is this knowledge or just a feeling? My feeling is that SPIN should be fast enough to convert 100 numbers into ASCII per second. Isn't it?
80_000_000 cycles per second makes 20_000_000 MIPS in PASM.
I measured some SPIN instructions when I started with the propeller and they needed ~450 cycles. Maybe some need more, some need less. So, you can have ~170 MSPINIPS per second. That should be enough to convert some more numbers into strings.
It has me pointed in the right direction for learning more about logging data to a SD card.
Alex
