Maze Questions
Please move this topic if it is supposed to be in another forum.
Problem:
The Boe-Bot constantly hugs the walls of the maze, and the IR detectors are seeing to far ahead, causing the Boe-Bot to turn to early. I do not know the values to change in order to solve this problem. I'm trying to do the maze with both the maze code found here:
http://forums.parallax.com/forums/?f=6&m=341331&g=341331
And the RoamingWithIr.bs2 code.
I tried writing my own code for the maze, but I do not have a full understanding of the coding that the Boe-Bot uses. I would appreciate any help in furthering my understand of the code.
Details:
The maze contains 90-degree turns as well as a curved wall. Over the top of the maze is a small overhang that holds the maze together, and runs through its center length wise. I'm using the 2000-2007 Rev-C Boe-Bot. I have the BASIC Stamp Editor 2.1.
I will provide the measurements of the maze if you like.
I know the basics of the programming, but I think this maze requires a bit better understanding.
Problem:
Details:
Powered by enthusiasm
My partner tried this, however the IR detectors stopped working completely when the resistors were strengthened. Is their a resistance cap? What would be the best strength for a maze? Could something be wrong with the Boe-Bot?
