Prop Boe Bot
Hi guys I didn't realize that on the Prop Proto board the servo headers were not connected to the prop chip?? I want to build it the exact same way everyone else did using the prop proto board so I can use the existing code
can you guys please tell me what pins to use from the prop chip to servo headers thanks
FemtoBasic, BoeBotBasic, and several others in the Object Exchange are all variations of the same Basic interpreter and share one documentation file. The PDF file explains the common parts, then the parts that are unique to each variation.
