I'm having trouble understanding this floating reset business. Regardless of /BOE, it seems like a floating reset is just asking for trouble. Can someone please explain the rationale?
@mpark, I've sent propeller questions to the support email address you mention in the rare cases when I have not been able to find an answer in the propeller forum. They usually respond, but not always. You could also try giving them a call.
24 bit LCD Breakout Board now in. $21.99 has backlight driver and touch sensitive decoder.
ie - is it 10K ish, etc ???
Style and grace : Nil point
www.parallax.com/Portals/0/Downloads/docs/prod/prop/32212-32812-PropellerProtoBoard-v1.3.pdf
Post Edited (Toby Seckshund) : 12/24/2009 3:10:36 PM GMT
OK, I think you're referring to this document: www.parallax.com/dl/docs/prod/prop/Propeller-ProtoBoard-v1.1.pdf
That one does show BOEn tied to ground. But it's an old version (1.1). The "typo" is in 1.3. Hopefully it'll be corrected in 1.4.
David
www.parallax.com/Company/ContactUs/tabid/66/Default.aspx says support(at)parallax.com is for BASIC Stamp and SX support and doesn't say anything about Propeller support.
Rgds, David
