My first Basic Stamp project (SERIN and Code Questions)
Hello, I am trying to create communication between a BS1 (Transmitter) and BS2 (Receiver) to do three simple functions: turn LED 1 on/off, turn LED 2 on/off, or turn both LEDs off from whatever state they are in.
To do this, I have 3 buttons attached to the transmitter to put a voltage across pins 1,2, or 3 on the BS1.
I'm currently using a TWS-434a and RWS-434 to transmit and receive. Unfortunately, I haven't had any success, and I am not sure if it is my wiring, or my code. I have not received any syntax errors, but I wonder if the following code would be good to perform the functions I have in mind? Thanks for your time and suggestions.
Transmitter:
Receiver:
Transmitter:
' {$STAMP BS1}
SYMBOL slowdown = B3
SYMBOL code = W4 'The code determines the receiver operation'
SYMBOL synch = W5 'The synch is like the starting key'
SYMBOL junk = B6 'Junk gets the receiver running'
LET junk = 123
LET synch = 63158
DIRS = %00000001
LET code = 000
Start:
PAUSE 30
slowdown = 1
IF PIN1 = 1 THEN Operation1 'Depending on which button is depressed'
IF PIN2 = 1 THEN Operation2 'A different code is sent'
IF PIN3 = 1 THEN Operation3
IF PINS = %00000000 THEN Pauser
IF slowdown = 1 THEN Start
IF code <> 000 THEN Transmit
IF slowdown = 0 THEN CodeReset
PAUSE 70
GOTO Start
Operation1:
LET code = 11013
RETURN
Operation2:
LET code = 21013
RETURN
Operation3:
LET code = 31013
RETURN
Pauser:
LET slowdown = 0
RETURN
CodeReset:
LET code = 000
RETURN
Transmit:
SEROUT 0,N2400,(junk,synch,code) 'This sends the junk, followed by the synch'
RETURN 'and code'
Receiver:
' {$STAMP BS2}
synch CON 63158 'This tells the receiver what to expect'
BAUD CON 16780
code VAR Word
DIRH=%11111111
Start:
SERIN 0,BAUD,[noparse][[/noparse]WAIT(synch),code]
IF code=11013 THEN Light1 'Depending on code values'
IF code=21013 THEN Light2 'One of three operations will run'
IF code=31013 THEN Light3
GOTO Start
Light1:
TOGGLE 14 'Turns the 1st set of lights on or off'
RETURN
Light2:
TOGGLE 15 'Turns the 2nd set of lights on or off'
RETURN
Light3:
LOW 14 'Turns all lights off'
LOW 15
RETURN
You could also skip the use of "<next label>" and just do:
My questions still relate to SERIN/SEROUT Syntax, as well as actual circuit connections. I'm using a couple of 433 MHz transceivers presently.
For one, I assume I should use pull down resistors for on the TX-RX pins?
Furthermore, should I use pull down resistors on my data output/input pins?
When using SEROUT with a BS1 module, if I want to just store a number into a word variable, like 11013 in my first post, should I place a '#' before the variable name? (As seen in the code to follow)
To go along with that, when using SERIN, should I place DEC before the variable name on the BS2 Module?
Here are some pieces of code, so far I haven't gotten a response from the receiver, even when directly connecting the receiver and transmitter data pins.
BS1 Transmitter Excerpt:
BS2 Receiver Excerpt
