I'm trying to do my first assembly code, but no luck
I'm just starting with the propeller. As an exercise I've written in spin an numerical method to estimate pi and want to do the same in assembly.
In spin, I've used an object (object) to do the floating point math. This object appears to support floating point in assembler, but I'm not able to figure out how to use these features in assembler.
I've attached the assembler version of the algorithm, but I'm not able to figure out how to connect the floating point features to my code.
Any assistance would be helpful.
Robert
Robert
You'd need to use Float32Full rather than Float32A if you want to create a user-defined-function. Look at the documentation and the source code for Float32Full.
I'm still not sure what to do though. p8 only has a snippet of code. I still can't make the connection with what is written to what I need to do.
I want to use the functions in the library. With Spin, I just reference them in the OBJ section. How is this done in assembler?
@@@EDIT@@@
I just saw the second post. I tried to copy the assembler code to mine, but there must be something more to the user-defined functions that I don't understand.
1) Remove some of the routines from Float32 to make room for your code. Probably Sin and Cos. You'd substitute your code for them and probably use the same calls from Spin to call your routine (make both Sin and Cos call your routine).
2) Use the user-defined-function mechanism in Float32Full/Float32A. This essentially provides an interpreter for a simple instruction set (see FFuncCmd through JmpNaNCmd and FAddCmd through CeilCmd in the list of command constants at the beginning of Float32Full.spin) with the commands in the upper 16 bits of a long and some kind of operand in the lower 16 bits. You'd then call FFunc with the address of the interpretive code as a parameter. As shown in the documentation, the first long has to be a JmpCmd with the lower 16 bits being the address of the JmpCmd. A zero long ends the list. Jumps (Jmp...) are relative to the first long.
stevenmess2004's solution would probably work except there's no provision for returning the result to the Spin code and signalling that your assembly routine is done. The "ret" from Toggle won't work because there's no way to return to the other cog.
Post Edited (Mike Green) : 12/12/2009 6:23:12 AM GMT
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ flt : "Float32Full" PUB Main | startTime, elapsed flt.start startTime := cnt ' Starting time flt.FFunc(@Compute) ' Do computation elapsed := cnt - startTime ' Elapsed time DAT Compute long flt#JmpCmd + @Compute ' Establish starting address LoopIt long flt#LoadCmd + @j ' Get starting value long flt#FAddCmd ' Increment it long 1.0 long flt#SaveCmd + @j long flt#FMulCmd ' Multiply by two long 2.0 long flt#SaveCmd + @temp1 ' Save to be able to square it long flt#FMulCmd + @temp1 ' Now we have (j * 2) * (j * 2) long flt#FSubCmd ' (4 * j^2) - 1 long 1.0 long flt#SaveCmd + @temp2 ' Save so we can swap long flt#LoadCmd + @temp1 long flt#FDivCmd + @temp2 ' (4 * j^2) / ((4 * j^2) - 1) long flt#FMulCmd + @temp3 ' Multiply by previous result long flt#SaveCmd + @temp3 ' Save for next time long flt#LoadCmd + @j ' Check count for limit long flt#FCmpCmd long 100000.0 long flt#JmpLtCmd + @LoopIt long 0 ' End of user function j long 0.0 ' Loop counter temp1 long 0.0 temp2 long 0.0 temp3 long 1.0 ' ResultPost Edited (Mike Green) : 12/12/2009 5:09:33 PM GMT
I'll dig into this some more and see what I come up with.
Is this line of your example code in error?
long flt#LongCmd + @j ' Check count for limit
Robert Watkins,
I will see you over at Dee's tonight, and I can look at your code in person there.
Welcome aboard to the forum!!
Beau Schwabe
IC Layout Engineer
It would be nice if Cam could provide a little more documentation on this. I'm still figuring out the details by going through his code. I'm at the point where I can see mostly what he's done with the user-defined-function stuff, but not why. I'm sure that'll come eventually.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ flt : "Float32Full" Debug : "FullDuplexSerialPlus" fString : "FloatString" PUB Main | startTime, elapsed Debug.start(31, 30, 0, 57600) Waitcnt(clkfreq*2 + cnt) Debug.tx(Debug#CLS) flt.start startTime := cnt ' Starting time flt.FFunc(@Compute) ' Do computation elapsed := cnt - startTime ' Elapsed time elapsed := elapsed / clkfreq debug.str(String("Time ")) debug.dec (elapsed) Debug.str(String("[img]http://forums.parallax.com/images/smilies/tongue.gif[/img]i=")) debug.str(fstring.FloatToString(temp3)) 'Debug.str(String(":iterations=")) 'Debug.str(fstring.FloatToString(j)) DAT Compute long flt#JmpCmd + @Compute ' Establish starting address LoopIt long flt#LoadCmd + @j ' Get starting value long flt#FAddCmd ' Increment it long 1.0 long flt#SaveCmd + @j long flt#FMulCmd ' Multiply by two long 2.0 long flt#SaveCmd + @temp1 ' Save to be able to square long flt#FMulCmd + @temp1 ' Now we have (j * 2) * (j * 2) long flt#SaveCmd + @temp1 long flt#FSubCmd ' (4 * j^2) - 1 long 1.0 long flt#SaveCmd + @temp2 ' Save so we can swap long flt#LoadCmd + @temp1 long flt#FDivCmd + @temp2 ' (4 * j^2) / ((4 * j^2) - 1) long flt#FMulCmd + @temp3 ' Multiply by previous result long flt#SaveCmd + @temp3 ' Save for next time long flt#LoadCmd + @j ' Check count for limit long flt#FCmpCmd long 100000.0 long flt#JmpGtCmd + @LoopIt long flt#LoadCmd + @temp3 long flt#FmulCmd long 2.0 long flt#SaveCmd + @temp3 long 0 ' End of user function j long 0.0 ' Loop counter temp1 long 1.0 temp2 long 1.0 temp3 long 1.0 ' Result''Calculate pi numerically CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 OBJ Debug : "FullDuplexSerialPlus" fMath : "Float32" fString : "FloatString" PUB Calculate | a, b, c, i, j, time fMath.start Debug.start(31, 30, 0, 57600) Waitcnt(clkfreq*2 + cnt) Debug.tx(Debug#CLS) b := 1.0 a := 1.0 i := 0 j := 1.0 time := cnt repeat i from 1 to 100000 b := fmath.FMul(fmath.FMul(2.0,j),fmath.FMul(2.0,j)) b := fmath.FDiv(b,fmath.FSub(b,1.0)) a := fmath.FMul (a,b) j := fmath.FAdd (j,1.0) a := fmath.FMul (a,2.0) time := time - cnt time := time / clkfreq debug.str(String("Time ")) debug.dec (time) Debug.str(String(":")) debug.str(fstring.FloatToString(a)) Debug.str(String(":")) b := pi c := fmath.FSub(a, b) Debug.str(String("Caluclated Pi - System Pi = ")) debug.str(fstring.FloatToString(c))The spin is 24 seconds and the assembler is 8 seconds, though getting all cogs working together, we should get 2?
After reviewing your code example last night with Robert, I think I understand the user defined Function option within
the Float32Full.
Basically in a way the 'Float32A' is written to serve as an interpreter for what you place in the DAT section longs.
Given that, I am reposting Mike's code with heavy comments. Hopefully this will make better since as it wasn't obviously
clear to me at first when I sat down to look at this method to define a user function within the Float32Full.
[b]CON[/b] [b]_clkmode[/b] = [b]xtal1[/b] + [b]pll16x[/b] [b]_xinfreq[/b] = 5_000_000 [b]OBJ[/b] flt : "[b]Float[/b]32Full" Debug : "FullDuplexSerial" fString : "FloatString" [b]PUB[/b] Main | startTime, elapsed Debug.start(31, 30, 0, 38400) [b]Waitcnt[/b](clkfreq*2 + [b]cnt[/b]) Debug.tx(0) flt.start startTime := [b]cnt[/b] ' Starting time flt.FFunc(@Compute) ' Do computation elapsed := [b]cnt[/b] - startTime ' Elapsed time elapsed := elapsed / clkfreq debug.[b]str[/b]([b]String[/b]("Time ")) debug.dec (elapsed) Debug.tx(13) Debug.[b]str[/b]([b]String[/b]("i=")) debug.[b]str[/b](fstring.FloatToString(temp3)) 'Debug.str(String(":iterations=")) 'Debug.str(fstring.FloatToString(j)) [b]DAT[/b] Compute [b]long[/b] flt#JmpCmd + @Compute ' Establish starting address to define a function called "Compute" '--------------------------------------------------------------------------------------------------------------------- LoopIt [b]long[/b] flt#LoadCmd + @j ' Load the accumulator of the "Float32A" interpreter with the value of "j" '--------------------------------------------------------------------------------------------------------------------- [b]long[/b] flt#FAddCmd ' Add 1 to the accumulator [b]long[/b] 1.0 '--------------------------------------------------------------------------------------------------------------------- [b]long[/b] flt#SaveCmd + @j ' Copy the accumulator into "j" '--------------------------------------------------------------------------------------------------------------------- [b]long[/b] flt#FMulCmd ' Multiply the accumulator by two [b]long[/b] 2.0 ' Now we have (j * 2) '--------------------------------------------------------------------------------------------------------------------- [b]long[/b] flt#SaveCmd + @temp1 ' Copy the accumulator into "temp1" '--------------------------------------------------------------------------------------------------------------------- [b]long[/b] flt#FMulCmd + @temp1 ' Multiply the accumulator by "temp1" ' Now we have (j * 2) * (j * 2) ...or... (4 * j^2) '--------------------------------------------------------------------------------------------------------------------- [b]long[/b] flt#SaveCmd + @temp1 ' Copy the accumulator into "temp1" '--------------------------------------------------------------------------------------------------------------------- [b]long[/b] flt#FSubCmd ' Subtract 1 from the accumulator [b]long[/b] 1.0 ' Now we have (4 * j^2) - 1 '--------------------------------------------------------------------------------------------------------------------- [b]long[/b] flt#SaveCmd + @temp2 ' Copy the accumulator into "temp2" ; so we can swap '--------------------------------------------------------------------------------------------------------------------- [b]long[/b] flt#LoadCmd + @temp1 ' Load the accumulator with the value of "temp1" ' Now we have (j * 2) '--------------------------------------------------------------------------------------------------------------------- [b]long[/b] flt#FDivCmd + @temp2 ' Divide the accumulator by "temp2" ' Now we have (4 * j^2) / ((4 * j^2) - 1) '--------------------------------------------------------------------------------------------------------------------- [b]long[/b] flt#FMulCmd + @temp3 ' Multiply the accumulator by "temp3" ; Multiply previous result '--------------------------------------------------------------------------------------------------------------------- [b]long[/b] flt#SaveCmd + @temp3 ' Copy the accumulator into "temp3" ; The Result '--------------------------------------------------------------------------------------------------------------------- [b]long[/b] flt#LoadCmd + @j ' Load the accumulator with the value of "j" ; Check count for limit '--------------------------------------------------------------------------------------------------------------------- [b]long[/b] flt#FCmpCmd ' Compare the accumulator value against 100000 and store result back into ' the accumulator [b]long[/b] 100000.0 '--------------------------------------------------------------------------------------------------------------------- [b]long[/b] flt#JmpGtCmd + @LoopIt ' If the accumulator indicated that the previous comparrison was less than ' the compared value then Jump to the Address labeled "LoopIt" and repeat ' the process all over again. '--------------------------------------------------------------------------------------------------------------------- [b]long[/b] flt#LoadCmd + @temp3 ' Load the accumulator with the value of "temp3" '--------------------------------------------------------------------------------------------------------------------- [b]long[/b] flt#FmulCmd ' Multiply the accumulator by "2" [b]long[/b] 2.0 '--------------------------------------------------------------------------------------------------------------------- [b]long[/b] flt#SaveCmd + @temp3 ' Copy the accumulator into "temp3" ; The Result '--------------------------------------------------------------------------------------------------------------------- [b]long[/b] 0 ' End of user function ; Terminates user defined function '--------------------------------------------------------------------------------------------------------------------- '--------------------------------------------------------------------------------------------------------------------- '' User defined variables to be used in function '--------------------------------------------------------------------------------------------------------------------- j [b]long[/b] 0.0 ' Loop counter temp1 [b]long[/b] 0.0 temp2 [b]long[/b] 0.0 temp3 [b]long[/b] 1.0 ' Result▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 12/13/2009 9:04:56 PM GMT
The lower 16 bits of a floating point "instruction" is usually the address of the operand (a long in hub memory). If it's zero, the next LONG is taken as a literal constant.
The floating point accumulator is initialized to zero. The value left in the accumulator is returned as the result of the FFunc Spin call.
Notice that there are no provisions for arrays or subscripting or integer calculations. This facility is really intended for implementing new functions, not complex whole programs which are intended to be done in Spin where those capabilities are available.
