Conditional statements and QTI's
                    I'm working with the line follow code that is supplied with the QTI sensor kit.  It works great but I have two situations where the sensors read
CASE %1110
and I need to distinguish between them so that I can run different subroutines at different times. I have tried using "IF THEN" statements but I am not
getting the desired results. Is there some way to make the "case" both a condition and a variable? I am new to pbasic and would appreciate any help that is offered.
                            CASE %1110
What are the two conditions that causes the sensors to read %1110, and what makes them different? If you attach the code that you have, it can help us get a better understanding of what you want to do.
One solution would be to have the CASE %1110 go to a subroutine with IF...THEN statements to make another decision based on other parameters. But also keep in mind that you can only nest 4 subroutines before the program will get lost.
Hope this helps.
-- Jessica
Jessica Uelmen
Education Department
Parallax Inc.
I have been successful at programing both of these individual series of operations with sub routines but have not found a way to have both perform.
The code is
' {$STAMP BS2} ' {$PBASIC 2.5} qtis VAR Nib 'qti black/white states OUTB = %1111 DO GOSUB Check_Qtis SELECT qtis CASE %1000 PULSOUT 13, 650 '13 left PULSOUT 12, 650 '12 right CASE %1100 PULSOUT 13, 750 PULSOUT 12, 650 CASE %0100 PULSOUT 13, 800 PULSOUT 12, 650 CASE %0110 PULSOUT 13, 840 PULSOUT 12, 650 CASE %0010 PULSOUT 13, 850 PULSOUT 12, 700 CASE %0011 PULSOUT 13, 850 PULSOUT 12, 750 CASE %0001 PULSOUT 13, 850 PULSOUT 12, 850 CASE %1110 PAUSE 500 ' Stop for 1/2 second GOSUB second_base ' Turn approximately 45deg clockwise, resulting in right turn GOSUB servo14 ' Activate continuous servo for firing mechanism GOSUB line_return1 ' Turn approximately 135deg counter-clockwise, resulting in left turn and returning to line follow counter VAR Word FOR counter = 1 TO 25 ' Servos rotate simultaniously in opposite direction PULSOUT 12, 650 ' causing unidirectional motion PULSOUT 13, 750 PAUSE 20 NEXT CASE %1111 PAUSE 500 ' Stop for 1/2 second GOSUB third_base ' Turn approximately 90deg clockwise, resulting in right turn 'PAUSE 1000 GOSUB servo14 ' Activate continuous servo for firing mechanism GOSUB line_return2 ' Turn approximately 135deg counter-clockwise, resulting in left turn and returning to line follow CASE %0000 PULSOUT 13, 750 PULSOUT 12, 650 CASE ELSE PAUSE 3 ENDSELECT LOOP '----------TURN TO SHOOT @ 2ND BASE SUBROUTINE--------- second_base: FOR counter = 1 TO 38 ' Servos rotate simultaniously in opposite direction PULSOUT 13, 850 ' causing unidirectional motion PULSOUT 12, 850 PAUSE 0 NEXT RETURN '----------TURN TO SHOOT @ 3RD BASE SUBROUTINE--------- third_base: FOR counter = 1 TO 80 ' Servos rotate simultaniously in opposite direction PULSOUT 13, 850 ' causing unidirectional motion PULSOUT 12, 850 PAUSE 0 NEXT RETURN '----------SERVO 14 SUBROUTINE----------------- servo14: FOR counter = 1 TO 1000 PULSOUT 14, 850 NEXT PAUSE 500 RETURN '----------LINE RETURN 1 SUBROUTINE--------- line_return1: FOR counter = 1 TO 113 ' Servos rotate simultaniously in opposite direction PULSOUT 13, 650 ' causing unidirectional motion PULSOUT 12, 650 PAUSE 0 NEXT RETURN '----------LINE RETURN 2 SUBROUTINE--------- line_return2: FOR counter = 1 TO 150 ' Servos rotate simultaniously in opposite direction PULSOUT 13, 650 ' causing unidirectional motion PULSOUT 12, 650 PAUSE 0 NEXT RETURN Check_Qtis: 'Result -> qtis variable. 0 means white surface, 1 means 'black surface DIRB = %1111 'P7..P4 -> output PAUSE 0 'delay = 230 us DIRB = %0000 'P7..P4 -> input PAUSE 0 'Delay = 230 us qtis = INB RETURNI hope this more clearly defines my difficulty. Thanks you again for any and all help
I know this is the condensed version, but if you need more detail and nobody else chimes in before I return from my trip today, I can talk more then.
Gotta run,
Ron aka sailman58
