Cheapest solution to send an email? — Parallax Forums
SRLMSRLM Posts: 5,045
edited 2010-01-03 10:28 in Propeller 1
I am looking for some sort of module that will allow me to send an email via serial commands. Something like "email:user@domain.com content:"Hello World!" would be ideal. Of course, it should also be cheap since it will be incorporated into a design that I will make for a number of friends, and we are all students. The module doesn't have (and preferably doesn't) to have a web server feature.
I suspect that a standalone propeller can do it, and that is fine if the code isn't too complicated. I don't want to have to learn (yet) the whole foundation protocols of the internet. There are also a number of chips and modules like the Prop NIC from Spin Studio, but that is $30.
So, any cheap and simple solutions to send an email from serial commands?
Powered by enthusiasm
    edited 2009-12-11 08:50
    You already have a PC. Would a program running on that, in conjunction with a serial port, work?
  • TubularTubular Posts: 4,726
    edited 2009-12-11 09:07
    I seem to remember mail servers have quite a simple "texty" command interface. You can probably telnet to your existing mail server and have a looksee.
    Of course going that path would still require an internet connection, but you could use a serial based dial up connection (this would be dirt cheap except for the call costs, but assumes you have phone line access)
    Another approach is to use a wireless GSM modem. I've used the Telit modules which have a script for sending the email across to the net. They're not that cheap, $50ish. Jay Kickliter was doing something interesting on this forum with cheap motorola cellphones... not sure if SMS or Email, but you can easily bridge from one to other.
  • VIRANDVIRAND Posts: 656
    edited 2009-12-11 10:24
    Before broadband it used to be easy, you could program in BASIC to send strings to a modem
    like ADTD 555-1212 (but that is a wrong number) and wait for receiving a login string and
    then send your email name and password
    and then use your choice of email programs. The last server I knew of that I could do that on was
    sdf.lonestar.org, which was a free personal server, and might still exist, but if not, you could
    make your own on a linux box. I haven't done that though. It should also be possible and easy
    and faster on Propeller and the ethernet module, just look up SMTP protocol and it should be as easy as
    with the dialup modem and automatic login string handling in Spin.
    But you'll need an ISP or web host service in any case. Your own internet access provider or
    coffee shop is not going to let you send spam from email addresses that aren't yours or theirs,
    unless they are so bad that they don't mind being blocked as spammers by most other ISPs.
    Maybe I'm answering the wrong question. If you get the ethernet module and Spin web server demo,
    you can permit sending email with the HTML "mailto:name@domain.com" feature. Also I imagine it
    would require a lot of parsing but you could use Spin to generate the dynamic HTML needed to
    have an email like service even without a domain name which might be like just texting on a
    website from user to user, or a BBS, or like a facebook wall.
    If you want to give all your friends your own version of email like google, aol, hotmail, then you
    buy a domain name with a web hosting service that has a nice basic package with a lot of email boxes
    for maybe less than $10 a month, like AllYourFriendsNames@SRLM.NET . Since it is a web host
    you could use the website for social networking with a free sofware HTML editor like NVU, with the benefit
    of not being OWNED by facebook and the disadvantage of it not being so dumbed down, or as a blog without
    any software. You don't need a web page but the 404 might be embarrassing if someone tries to browse
    your domain. Often the email service options are Webmail, much like google and hotmail, or "POP" which is
    the protocol that is probably how Outlook express or Thunderbird gets your mail. Again, the Propeller can
    send SMTP messages to the host server to forward to EITHER your friends old email addresses OR the
    POP or WEBmail boxes provided by the host. For anything special, you'd have to find out how to write
    server-side applications and make sure the host can and will accept them. By special I don't mean
    sending email by Propeller (which might as well be a PC) but if you have a totally innovative way of
    doing email that your ISP doesn't already do, for example by using voice recognition over the phone
    to send email without typing it. BY THE SIZE OF THIS PARAGRAPH I'LL ASSUME THAT IT IS FULL OF
    OLD AND UNNECESSARILY COMPLICATED STEPS AND SOMEONE HAS NEWER BETTER EASIER IDEAS.
    I also would assume that otherwise most people know how to make web pages and get email accounts,
    so I must be answering the wrong question again and someone else will have a better answer that
    is more focused on sending email from the Propeller in a simple easy modern way
    I imagine that that may involve a Propeller as a mail server , but it still needs DNS and a domain name,
    which can be obtained apart from a host for less than $10 a YEAR (vs hosting which is billed similarly on a
    Monthly basis but I believe it is likely possible that the Propeller can host for free if all your friends
    email can fit on an SD card). But lets see what new ideas others have and how bizarre my ideas are.
    If you're all on a campus with wi-fi everywhere and you don't need NEW email addresses then you just
    send SMTP protocol from the Propeller using your existing local email addresses as a laptop would, using
    whatever Propeller wifi module which I heard (a rumor) was available.
    Post Edited (VIRAND) : 12/11/2009 10:35:49 AM GMT
    edited 2009-12-11 14:45
    You can send an email with a simple telnet session which Harrison's driver supports.
    Should be a simple trick to send & even receive an email with a Propeller and
    PropNIC type configuration.
    Here is a link to sending an email with a telnet type session. There is also a link
    to reading an email this way as well.
    www.wikihow.com/Send-Email-Using-Telnet
    OBC
    New to the Propeller?
  • stevenmess2004stevenmess2004 Posts: 1,102
    edited 2009-12-11 23:55
    There is an object in the obex that recieves emails using pop3. You may be able to get that to send emails. obex.parallax.com/objects/259/
  • SRLMSRLM Posts: 5,045
    edited 2009-12-12 07:47
    Thanks everyone for the replies. I will address them one at a time:
    PhiPi said...
    Unfortunately, no. I happen to have three computers running in my room, but others don't. The system needs to be able to send an email regardless of where a computer is.
    Tubular said...
    I have already tried to log into our mail server with a text interface (via a PC). It says it requires a telnet session, but when I try that it denies me. Either my internet protocol knowledge is lacking or it isn't possible.
    VIRAND said...
    Everyone has a spare Ethernet port on the network that the module can be connected to. Since the project doesn't need to be mobile it's okay to keep it permanently plugged in.
    OBC said...
    With my utter lack of internet skills I can't get it to work just using a PC. I have tried on both my school email and personal email, and neither wants to cooperate. Mostly they just show a blank screen. I tried both CMD telnet and PuTTY.
    This is turning out to be more difficult than I thought... BTW, outgoing mail doesn't have to be from any particular domain name or email address. It just has to go somewhere since it's for a notification scheme.
  • BradCBradC Posts: 2,601
    edited 2009-12-12 07:49
    SRLM said...
    Stupid question, but you were actually trying to connect to port 25 weren't you?
    If you always do what you always did, you always get what you always got.
    edited 2009-12-12 07:56
    brad@bklaptop2:~$ telnet mail.fnarfbargle.com 25
    Trying 93.93.128.63...
    Connected to mail.fnarfbargle.com.
    Escape character is '^]'.
    220 fnarfbargle.com ESMTP Exim 4.69 Sat, 12 Dec 2009 07:55:06 +0000
    MAIL FROM:testuser@fredbasset.net
    250 OK
    RCPT TO:dispose1@fnarfbargle.com
    250 Accepted
    DATA
    354 Enter message, ending with "." on a line by itself
    This is an email spanning
    Multiple lines that will appear in my inbox shortly
    250 OK id=1NJMpK-0000IO-88
    ^]quit
    Received: by bkcuk001 (mbox brad)
     (with Cubic Circle's cucipop (v1.31 1998/05/13) Sat Dec 12 07:57:23 2009)
    X-From_: testuser@fredbasset.net Sat Dec 12 07:56:00 2009
    Return-path: <testuser@fredbasset.net>
    Envelope-to: dispose1@fnarfbargle.com
    Delivery-date: Sat, 12 Dec 2009 07:56:00 +0000
    Received: from xxxxxxxxxxxxxxxxx ([noparse][[/noparse]xxx.xxx.xxx.xxx] ident=xxxxxxxx)
            by fnarfbargle.com with smtp (Exim 4.69)
            (envelope-from <testuser@fredbasset.net>)
            id 1NJMpK-0000IO-88
            for dispose1@fnarfbargle.com; Sat, 12 Dec 2009 07:56:00 +0000
  • kafferkaffer Posts: 1
    edited 2010-01-03 01:15
    SRLM,
    if I get it right, you and your friends wants to send to each other some notification msgs. If it is that so, you could just write your own protocol. If you have propellerdevices all/time powered, and you know their IP addresses, than the simpliest is to interconnect them with API_Telnet serial object via IP protocol - you don't have to dig into it, just use that object as opening a serial port to a known IP address.
    Email sending with Prop is a bit complicated, since modern smtp servers use secured connections to eliminate the usage of them for spamming.
    But if I were you I would use PropIRC and a known IRC server with a personalized chatroom or channel, and than you only have to solder the boards, download Propirc into them and there you go...
    edited 2010-01-03 01:50
    You could connect the Prop to a plug computer via the USB port, then use a script running on the plug computer to do the emailing and ethernet stuff. To me, this is an almost ideal division of labor, rather than shoehorning the network stuff into the Prop.
  • SamMishalSamMishal Posts: 468
    edited 2010-01-03 03:26
    BradC said...If you always do what you always did, you always get what you always got.
    Hi Brad,
    I always like to read your signature line....quite amusing.
    Samuel
    www.RobotBASIC.com
  • rjo_rjo_ Posts: 1,825
    edited 2010-01-03 06:26
    Cheapest?
    This probably isn't the cheapest... but in the long run it might be the best investment of your time, effort and money. And it is definitely fun stuff.
    I had this working at one point, so I know it is possible. I was using it to e-mail gps coordinates from my car, using a GE862. Get a GE865... with a breakout board, 865 included, is $99. It has a tiny footprint, is cheaper than the 862 and doesn't have the GPS unit.
    http://www.sparkfun.com/commerce/product_info.php?products_id=9297
    The 865 speaks serial... two wires from your Prop is all you need. No voltage leveling problem... just hook the wires up[noparse]:)[/noparse] Rx out of the board goes to your prop's rx line.
    You can even power it up from 3.3V.
    Once you are connected... you send the right series of AT commands and things will work just the way they are advertised.
    Don't bother with the built in Python programming environment of the GE865... it is a quagmire. But there are a couple of forums that provide python sources... which are easy to hack... since you are just extracting AT command sequences.
    With the Prop there is no muss and no fuss... When you are done developing, you won't have to have a connection to a computer. It will work anywhere. What could be better?
    You have to add a Sim card adapter... $14.
    Phil has posted a solution for using the audio transmit and receive lines to send serial over the phone... so you might want to buy two of the GE865s.
    Rich
  • DroneDrone Posts: 433
    edited 2010-01-03 07:24
    Umm... just use an Xport or WIZnet ethernet/UART module and mimic a telnet smtp session on port 25 with one of the serial objects on the Object Exchange.
    This ethernet/UART module is $24.95 qty.-1:
    www.sparkfun.com/commerce/product_info.php?products_id=9472
    How to test SMTP via telnet (google for many more examples):
    support.microsoft.com/kb/153119
    Rgds, David
  • Harrison.Harrison. Posts: 484
    edited 2010-01-03 09:14
    Drone said...
    Unfortunately that specific module is not a simple UART (async serial) module. It requires a bit of software to get TCP/UDP socket access, which is performed via SPI or memory mapped parallel I/O. Wiznet does have a serial<->ethernet module for $5 more (www.sparkfun.com/commerce/product_info.php?products_id=9476). I haven't used the serial module so I don't know if it will work for your purposes or not.
    SRLM said...
    I wouldn't really look too much into plain text SMTP over port 25. Most ISPs require SSL for SMTP and POP3/IMAP access for security and anti-spam reasons. A much better solution would be to have a remote server (a cheap webhost for example) that hosts a HTTP accessible script that will proxy your emails. That way the actual email sending is handled remotely, and all your Propeller device will have to do is send a HTTP GET or POST request to the webserver of your choice. I use this technique for many projects.
    SRLM said...
    As for hardware, the cheapest solution would be to use an ENC28J60 ethernet controller ($3 for the chip + $4 for the ethernet magnetics). You could also use one of the various Wiznet hardwired TCP/IP chips, which cost a little more than the ENC28J60 solution. Whichever route you choose, stay away from expensive breakout boards. The actual cost to build one of these interfaces from scratch is less than $10.
    Disclaimer (and shameless plug...): I'm a bit biased towards the ENC28J60 as I have used it in many projects. I even have a custom TCP/IP stack for the Propeller that targets it: harrisonpham.com/dp/proptcp.
    Hi Harrison, You're probably right about the WIZnet module. But the module you point out is true RS-232. So for direct interface with the prop, you would have to bypass what looks like an on-module FTDI chip.
    Good suggestion regarding the external server. I do this as well. I also use server side include information for determining the dynamic IP address of the remote device which can be served to other remotes by the off-site server which has a registered domain.
    At least where I live, most ISP's still support port 25 SMTP/POP without SSL provided you're connected on the inside of their network (via a DOCSIS cable modem for-example). SSL connections are only required when accessing email from the outside.
    Regards, David
