i have an ede1204 and i have it hooked up to my bipolar stepper motor with 2n2222 and an h-bridge. my only problem is i can't figure out how to get a program to work. the attached pdf is the only schematic i can find and page 5 has the circut i used
You can use wires to + and ground to test it. Page 1 and 2 have the pins and the settings. A 1 would be power and a 0 would be ground. Put a 330 ohm resistor in series with the jumpers to provide current protection.
- Stephen
