New Stingray fails motor test when powered from wall wart
Hiya!
I just received my Stingray kit this evening and couldn't wait to put it together... It's all assembled per the instructions, but I've run into an unexpected snag. The "Testing the Motors" programs on p. 25 of the instructions initially failed for me. They would basically twitch one wheel and then the board would flash the red undervoltage LED and spontaneously reset! I double-checked all the connections and was about to give up in frustration when it occurred to me to try the test powered from the battery pack rather than the 7.5V 1a (Parallax recommended and supplied) wall wart.
SO, I am guessing that the motor startup is exceeding the current available from the wall wart... But should it be? The specs on p. 24 say the motors should draw ~180mA with no load. I have the wheels attached (per instructions) but the bot is sitting on top of a Digi-key catalog so the wheels can turn freely. Is it possible to measure the current drawn somehow?
ISTR having read that electric motors draw significantly more current with switched on and thus it's preferred to "slow start" the motor using PWM, but this is Parallax's test regimen... If the test isn't expected to work with a wall wart, it would be nice if that were mentioned in the instructions!
Follow up: A simple test using the PWM_32_v2.spin object to do a slow-start worked fine on wall-wart power... So it appears to be an over-current like I suspected.
Post Edited (Nak) : 12/8/2009 8:47:03 AM GMT
Parallax Engineering
Unloaded, with electronics running and motors at about ~1/4 speed: 500ma
Stalled, with electronics running and motors set at about ~1/4 speed: 700ma
I suspect that if you were to test running the motors at full speed then you would get higher numbers. BTW, when you are accelerating the wheel (speeding up) it can't be considered to be unloaded. T = Ia...
Powered by enthusiasm
Overall I am quite favorably impressed with the Stingray kit! The instructions were clear and detailed and the machined parts fit together perfectly. This is *exactly* the starter kit for robotics that I was looking for... Basic, easy to understand and build, and a nice size to work with. Easily portable but still plenty of room for hand crafted add-ons. Great work from the Parallax team!
SRLM: Thanks for the info! I am still curious to know the instantaneous current drawn from the batteries when one of the motors is driven full on with no PWM. I don't even know how to go about measuring such a thing. Is this something an oscilloscope can do?
Your feedback is appreciated and noted. I will be working on the future accessories we had planned to release for the Stingray coming up very soon and at that time I will make revisions to various code, documentation, etc. based on feedback from customers since the initial release. Take care, and stay tuned for more!
