Parallax engineers, how do I interpret my oscilloscope data?
I did 5 samplings, all less than 5 seconds each except for the first one, which may have been, but the first one was definitely under 10 seconds. The first one should be completely different then the last 4, and they all look the same to me.
Can you please explain to me how to read these and interpret the data from them?
Sample 1
Log file to acompany it
stashbox.org/727595/idling_test1.txt
Sample 2
stashbox.org/727600/2ndgearinlift_test1.txt
Sample 3
stashbox.org/727603/2ndgearinlift_test2.txt
Sample 4
stashbox.org/727604/2ndgearinlift_test3.txt
Sample 5
stashbox.org/727605/2ndgearinlift_test4.txt
Sample 1
Sample 2
Sample 3
Sample 4
Sample 5
What is apparent to me at first glance is that the screenshots above are all identical. That is to say, it is not that there was no change in the signal...each screenshot is the same exact image, pixel for pixel. Due to random noise fluctuations it would be impossible to do this from an actual reading. Given that, there is no way to answer your question. You're missing the other 4 images and somehow have pasted the same one for all 5.
Parallax Engineering
Those are all 5 separate images, taken after 5 separate times that I hit the "run" and "stop" buttons after sampling data, is this a flaw in the oscilloscope or its software?
What I did notice is that none of the values on the right hand side update (as I feel they should) as soon as you hit the "run" button, there is always a large delay and when I'm taking 2 or 3 seconds of sample data, they don't update at all?
